Highbeam
A couple of guys ( one 90, the other in his 80's) came over and figured it out for me...
That gal does not look 90, or what I would describe as a guy. It could be that the old guys figured it out though.
Yes. The opening you see is to hold the ceiling support box (which supports the chimney). This opening is normally at minimum as built to spec for the support box. After that box, it gets wider. I climbed up and down that sucker about 50 times prior to putting in the support box, so I know it is big enough for an average sized male ( 24 by 24 inches actually).
Just be sure to trim that OSB back even with the framing, you'll will need to do that anyway so the box can be pushed up far enough. I'm sure that was the plan, just making sure.
I'm lost....
The hole in the ceiling is a box frame that the chimney support slides up into. I then reach up inside and screw it to the 2 by 4's. I don't think any trimming needs to be done, but correct me if I'm wrong. The sides of the chimney support box are 14 inches and therefore meet code.
A fresh coat if paint makes such a difference! Blaze King used Stove Bright Satin Black on their stoves until recently. If you want it to look like a late model, use Metallic Black. They switched to that a little while ago.I have done all the work myself up to the finish you see above. The finish above is a concrete finish. I thought about tiling which of course is more typical, but my Enerzone has the same concrete finish and we really like it. Also, the concrete finish was done while my family and I were on vacation so I was able to make progress before Fall even while going to Disney.
Next stop is the stove. While in good shape overall, I am adding a fresh cat, a door gasket, a bypass gasket, and a coat of paint. I did the door gasket two days ago, today I'll be cleaning up the stove and painting.
