- Sep 5, 2013
- 6
Had a Regency CI1250 insert installed recently. Stainless liner is insulated and runs up existing outside brick chimney, liner is capped at the top w/ std. cap. No block off plate or Roxul.
Using dry wood, 20% or less MC, loading unit full up to the top. Fan on unit doesn't turn on by itself until fire has been going a long time. Living room where liner is installed warms up but only a couple degrees.
Should also note that without insert running, the regular heating system keeps the house comfortable, so not a problem with drafty windows, etc. Also, only burning for several hours at a time, not continuously.
Is this kind of performance normal? I was wondering if anyone's had a similar experience, then added a block off plate with Roxul on top. How much improvement in the heat output did you notice?
