Buck stove vs empire vs big box store wood stove
OzarkGirl
1
North Central Arkansas
I am trying to figure out what brand and model wood burning stove to get for my newly built steel frame 1800 sq ft barndominimum home. Metal exterior with metal roof and spray foam insulation.
I live in north central Arkansas in the US so we have slightly mild winters but we can get nasty ice storms in February. The home is a single story, 14' ceiling, large open concept living room kitchen area, stained concrete floors.
The wood burning stove will mainly be used for fall/winter weekend burning/ambiance but also want it to perform if/when we lose power as we live on the White River (not a very big town and if roads are bad, may be without power for days).
I have zero experience with a wood stove or any heat source other than the typical forced air ac/heat furnace that has always been installed in my homes. After reading some of the posts on here I almost feel like this is a whole new world and you need some sort of masters degree in fire science to own and operate a stove. Am I in over my head? Is this something that is going to be a hassle just to have "in case of emergency"?
I assumed I would just buy a wood stove from the big box store in the next town over but someone told me they don't last. What does that mean?
So I was referred to a Buck stove, osburn or Vermont Castings. VC seemed the most expensive and I am definitely a bargain shopper that doesn't need all the bells and whistles. I also read that cast iron takes a long time to heat up. So if I am mainly just using it for the weekend, maybe cast iron is not the way to go for a quick heat? What am I supposed to be looking for?
I understand pipe and install is an additional expense but I'm able to spend around $2500-$3000 for the stove alone. Is that even getting me a good stove?
Someone please help me figure out if I should do this or just scrap the whole idea and wear long underwear, hoodies and watch the yule log on youtube all winter long.
Thanks for any tips you can give me. Again, anything helps as I have no knowledge of what I'm getting into.
  • [Hearth.com] Buck stove vs empire vs big box store wood stove
If you are a bargain shopper, look at the Drolet line of stoves. They are by the same company as Osburn as their value line, but they are good, reliable stoves. Depending on the size needed the savings can be notable.
Note that any stove will need dry, fully seasoned firewood to operate properly. Poorly seasoned wood causing poor heat and stove perfomance is the number one issue reported, especially for 1st time stove owners.
Reactions: OzarkGirl
Another possibility might be a used stove. Used is harder shopping, because you’ve got to figure out if it’s in good shape. But, say, a used Jotul might be a good looking stove that would perform well, if you can find a good one of appropriate size that hasn’t been abused. I don’t know how good the analogy is, but it’s like you could buy a used Mercedes for the price of a new Ford Escape. My previous stove was a Jotul I bought used for $900. I sold it for $900 after 15 years or so of good service (though I did have to swap out some parts in between. I ran it hard every day in Vermont winters, most of or heat.) It was a pretty little stove, looked great in our house, which matters to me. Same stoves seem to be going for a bit more on Craigslist this year, more like $1500.
Used VC might not be the best, even if it is the prettiest, because in general maintenance and repairs of those is a bit more expensive and complicated. I have had VC stoves but I don’t know them all. I think there are probably some good models that would be a good buy, like maybe a used old Resolute if you could find one.
Cast iron heating slowly, IDK, I guess I’ve mostly only had cast iron stoves, and now I have a soapstone stove. I think a bigger factor might be how easy a stove is to get burning well and how big the glass is. A good fire will throw a lot of heat through the glass right away. You’ll feel it nicely, even if it’s not warming up the whole room yet.
As said drolets are great stoves for the price. Another note on the wood, don't believe the seller that tells you his wood is fully seasoned. 90% of the time it isn't. Most wood you buy needs at minimum a summer of drying before it is ready to burn.
Or three summers split, stacked and top-covered in the wind if it's Oak. 😯 Two summers for a lot of other species.
Welcome to the forum.
You’re not in over your head. Research, and lots of it is key. Visit showrooms(in person and on line) to get an idea of what you like, talk to friends that have wood stoves. Go to chimney manufacturers websites, most have pictures/drawings of various chimney setups to handle different chimney configurations, from there you can get an idea of whats required for chimney and the associated cost.
Local and national code will layout what you can or can’t do…more research.
As mentioned above get your firewood now, if you decide later that wood burning isn’t for you, you can always sell it later.
