Got tired of bending over and hitting the ground too so I made this for my skid steer. Wife runs the skid, I run the saw...
Check baileys for the log rite stand attachment. They make those or Stihl, and I don't think I paid 40 for my stand.
gg
Dave, I hate those things and have nothing good to say about them. Much, much easier to roll the log onto one of the limbs you've cut off. Better yet is to cut some firewood length from the limbs and use 4-6 or more. Roll the log onto those and you have the log off the ground which is what you are striving for. In addition, it will save you about $100
The Woodchuck is a cool looking tool and if I didn't already have a Peavy it would be tempting, but in the end I'm with Dennis' KISS approach. It seems to work fine for me and I have yet to be unable to "unpinch" a bar using my wedges...and this saves me a few bucks too which is why I got into this hobby/pastime in the 1st place![]()
I have never used one of these things. I have seen and heard a bit about them but do not know if it would be that beneficial. I usually go down the log every 18 or 20 inches and just cut about half way through the log and then roll it over and cut through the other half. Seems to work fine. Sometimes if I have a larger tree I want propped up I can drop a small one across in front of it and then drop the bigger one on top of it after I have limbed it up. But, the woods I am working has way to many trees in it so this is not a problem. It needs a thinning out.
So do these timberjacks really help out that much? Like I said, I have never used one.
Got mine. attached it to the cant hook. On the ATV ready to go.
May get a chance to try it out this year if weather holds & the body says OK to go.
I bought this Peavey Timberjack a few years ago.
(broken image removed)
I took of the jack after the first time I tried it and haven't used it since. It makes a pretty good Cant hook without the jack. I'm with Dennis on the Timberjack.
Haha, I'm starting to realize that it isn't hard to tell what you really think Dennis! Let me really respectfully give another perspective and then at the same time stress that I have no where near the experience that you do yet with processing wood. With really large logs I agree about cutting them through 1/2way and then rolling them 1/2way to do the other 1/2way but for everything the timberjack can get its hook into, the timberjack is incredibly helpful with the steep terrain I'm often cutting on; previously when I attempted to use lengths of limbs to support the main trunk off of the ground I found the whole thing really likely to roll around and I definitely didn't like that. However when the timberjack was hooked in it tended to help by having the handle and by having the stand sort of anchor in and prevent the rolling that made the operation unsafe otherwise. Anyways just another $.02. Thanks.
This also how I have been doing it for the most part. But sometimes logs are a little big/heavy, and a lever to roll them onto thse cut pieces would be helpful. So would a "can't hook" be the tool to use for rolling in this fashion?Better yet is to cut some firewood length from the limbs and use 4-6 or more. Roll the log onto those and you have the log off the ground which is what you are striving for.
