That's exactly who I was thinking of...he still advocates for vertical splitting (while sitting on a milk crate)And our old Backwoods Savage would tell you to do all of this while comfortably sitting on a milk crate, although I usually just park another round in front of the splitter and use that as my seat
I do the same with the oak that tends to peel off of oak rounds. I lay it on the ground around the foot plate of the splitter, which not only helps them roll easier, but also preserves the grass from all the abuse.I was splitting 31” diameter 20” long oak rounds this weekend. Definitely struggled to manhandle the rounds onto my 27 ton Champion. Was using a peavey to work them in place.
On day two I laid a piece of plywood on the ground flush against the splitter. This was a game changer. This allowed me to roll the rounds onto the plywood and then used the peavey to just slide the round into place. Half of my problem I was having was fighting the round digging into the ground while I was moving it around. The plywood eliminated that issue all together.
Whatever works! I'm always pressed for time and horribly impatient, but I know everyone is not the same.Just a bit of a reply. My old splitter does indeed have a 6" cylinder with 2.25" ram . So yep, its slooow with that 11gpm pump. still beats wacking a wedge with a maul though.
High-tonnage splitters just don't make much sense to me, when you're sacrificing speed for unneeded excess splitting force.
In no case would it be easier to pick up the round and set it on a horizontal beam.
When I was 30 years old, picking up a 150-lb round was possible, but not desireable.I can't split vertically. It's much easier on my back to lift every piece up to the horizontal beam......and I also prefer tall beams, as being 6'5" I have to be able to stand straight.
40 years later it is absolutely impossible.
Vertical splitting is the only way to go except for gorillas.
The "work smarter not harder" thing to me means making the most exercise out of every piece of wood is the smarter part of that statement.
I see what you mean, sonny. Those wood chips you are splitting look like kindling to me.Everyone's situation is different. I half/quarter all the bigger stuff out in the woods where the tree is bucked to make it manageable for me to be able to load into my trailer. So when it comes time to split with my hydro splitter months later, I am picking up stuff that I have already picked up twice. LOL See, I look at it as I'm getting more bang for my buck in terms of exercise the more times I handle the splits.![]()
My back starts hurting 5 minutes into vertical splitting, whereas I can go a full day running it horizontally while picking up said wood, like -THIS-. Warning, video may not be suitable for those prone to motion sickness.
Everyone is different in what works for them.
If I could do this whole splitter thing over again, I would buy a 35-ton unit to get the bigger motor, bigger pump, bigger bung port on the reservoir, and then just downgrade the thing from a 6 inch to a 4 inch cylinder. It would give me what I already have now, but on a sturdier frame with lower cost.
I actually went the other way, starting with a Huskee 22-ton machine, and upgrading, engine, pump, lines, reservoir bung, etc. Same end result, but at much higher expense. I also suspect most 35 ton units usually come with a more substantial trailer tongue & kickstand than this 22-ton unit, although I've never done a brand-by-brand comparison on this.
The only thing I like better about my approach, is that by upgrading the engine, I was able to add electric start. Pull-starting an 11hp engine with a 16 or 18 gpm pump in January is no fun, but now I just plug it into the tractor and turn a key for that first cold start on a Saturday morning. Well worth the price of admission.
Been that way for the last 15 years the only way to go5 words:
Log lift with work table.
Nuff said.
Agreed...building one right now actually.5 words:
Nuff said.
Why not just buy a processor while you’re at it? Those things look like fun. Lots of good videos if you really can’t lift or move wood.5 words:
Nuff said.
Log lift with work table can be added to a splitter without adding alot of size. Processors tend to be a little more girthy.Why not just buy a processor while you’re at it?
And $$$!Processors tend to be a little more girthy.
