I have a corner fireplace, in the middle of a ranch home. Roof is flat where chimney is. Chimney stack is approximately 3-4 feet above roof line. No attic. Crawl under home. 1500 square foot home. I’m in Michigan. 5 acres wooded land. I’d like a back up power out heat source or switching to every day heat source. Looking for long burn and ability to heat house.
I looked at Lopi large insert next gen hybrid.
I have seen that the Blaze King stove rather than insert heats long, uses less wood, and will heat well without using power - which I love.
I do like the idea of using the top of a stove to heat food if needed as well.
What are your opinions please?
I’m open to lowering the base of the fireplace if needed.
It’s currently a fully functioning safe fireplace.
![[Hearth.com] Choosing between insert and stove inside fireplace [Hearth.com] Choosing between insert and stove inside fireplace](https://www.hearth.com/talk/data/attachments/331/331502-4d48f8815a99df9cf334f8be072d3e3d.jpg?hash=utYZrRYA4P)
![[Hearth.com] Choosing between insert and stove inside fireplace [Hearth.com] Choosing between insert and stove inside fireplace](https://www.hearth.com/talk/data/attachments/331/331503-47a55af8a437f6ab9141c8059c9e2ccb.jpg?hash=hGRaArjEZy)
![[Hearth.com] Choosing between insert and stove inside fireplace [Hearth.com] Choosing between insert and stove inside fireplace](https://www.hearth.com/talk/data/attachments/331/331504-a0a78e29e428e3fa65a4428d9164d839.jpg?hash=pDNytzq4TR)
