Why wouldn't it qualify?I hear where you coming from. I will toss out this Drolet 3000 only for its 100K + BTUs as a possible budget friendly option. Won’t qualify for the tax credit but would still cost less. That said it’s a different type of stove than the BK.
(broken link removed to https://www.drolet.ca/en/products/stoves/ht3000-wood-stove/)
I actually asked for pricing on both the F5200 and 3500. Still waiting on quotes.I would still consider the Regency F5200 a contender. Firebox size, burning time, hybrid, etc.
I am sorry but you may be able to vent a 6" stove into an 8" chimney. Many do it. Some have no problems others fight it constantly. And saying the king will handle it is absurd. It may but that is very doubtful. It may handle the square footage if it is well insulated and 8' ceilings. But this house is not. The btu rating of the king isn't very much higher than the princess and a princess barely keeps up with my 2000 sqft 70s ranch.If funds will allow, I would shoot for the king personally but not having the money says what to get! You can vent a 6” stove in a 8”, yes I said that, but shouldn’t vent an 8” stove in a 6” chimney. The king will handle that load by itself. Good luck on what you choose and congrats on the wife’s business.
My KE40 amply heats my 2850 sq. ft, home built in 1895. Yes I have tightened it up over the years and the OP plans on doing so as well. Your home and my home are very different but mine is not new or as tight as homes built in the past 50 years. But it does the job and in fact, my wife overheats the house all the time. House floor plan, fuels and fuel management, maintenance, annual sweeps etc are all part of getting the most from any stove. Up until this week, we had a cold snap of 20's and I fueled it once a day and kept the house in the 70's. Was the basement colder, yes, but all that is down there is a freezer full of 500lbs of halibut steaks!I am sorry but you may be able to vent a 6" stove into an 8" chimney. Many do it. Some have no problems others fight it constantly. And saying the king will handle it is absurd. It may but that is very doubtful. It may handle the square footage if it is well insulated and 8' ceilings. But this house is not. The btu rating of the king isn't very much higher than the princess and a princess barely keeps up with my 2000 sqft 70s ranch.
I also woke up to 8 degrees with a wind chill of -4 this morning. A king may heat the house in question after things are tightened up. But allot of that depends on the quality of the log construction. I have been in log houses that were very air tight and others that even after tons of work were drafty ad hell. I wasn't bashing bk at all just commenting that 3600 sq ft of drafty house and windows with the stove in a great room is allot to heat with any stove.My KE40 amply heats my 2850 sq. ft, home built in 1895. Yes I have tightened it up over the years and the OP plans on doing so as well. Your home and my home are very different but mine is not new or as tight as homes built in the past 50 years. But it does the job and in fact, my wife overheats the house all the time. House floor plan, fuels and fuel management, maintenance, annual sweeps etc are all part of getting the most from any stove. Up until this week, we had a cold snap of 20's and I fueled it once a day and kept the house in the 70's. Was the basement colder, yes, but all that is down there is a freezer full of 500lbs of halibut steaks!
As for stack diameter, no one should consider reducing the King down in size and expect desired performance. There would be concerns, not the least of which is smoke spillage into a home is terrible and creates an unhealthy environment. And in comparing a King to a Princess, @bholler is correct, the main difference is the size of the fuel tank.
I’m not so sure. I went with the princess because I was told I would have to run the king model on a ow setting to often. It’s a bigger stove with bigger surface area. You can crank the king stoves up and they will burn through the wood just like any other stove which in my mind is basically pumping out the same heat as any other with the same wood. It’s kind of a waste doing it since it takes away the free energy the cat will produce. If you can afford the king model, that’s what I would do. If you buy the princess, it can definitely pump out a lot of heat or it can be set as a helper and pump out a good consistent heat for 12-24 hoursWhat I’m taking away from this conversation is that the main advantage of king over Princess is longer burn time, not necessarily higher btu output?
What is a cold stretchKentucky winter weather is worth giving some thought as well. Not exactly frigid from what google saysWhat is a cold stretch
@EvertonPete ?
You must have a very drafty house! I said the king for the amount of wood it will take. He might have to fill it 3-4 times a day, I don’t know, you don’t know!I am sorry but you may be able to vent a 6" stove into an 8" chimney. Many do it. Some have no problems others fight it constantly. And saying the king will handle it is absurd. It may but that is very doubtful. It may handle the square footage if it is well insulated and 8' ceilings. But this house is not. The btu rating of the king isn't very much higher than the princess and a princess barely keeps up with my 2000 sqft 70s ranch.
Typical 70s ranch that was house wrapped 15 years ago. So not horribly drafty. The regency 3100 heated the house easily on 8 hour loading cycles untill single digits with high wind. The princess can't maintain temp well at 8 hours much under 20. It is entirely possible it doesn't matter how many times he loads it there may not be enough btus to heat the house untill it gets sealed up. Have you looked at the btu ratings? They are not all that high.You must have a very drafty house! I said the king for the amount of wood it will take. He might have to fill it 3-4 times a day, I don’t know, you don’t know!
I almost always run on 8 hour burn cycles if I am home I may open it up more and load more often. But if it can't heat my house for 8 hours it can't serve as my only heatI think it depends on the installation. Many people in New England live in older homes. I would not be surprised at all if most are running their stoves for high heat output in the current cold snap.
Why aren’t you using the regency anymore then since it did fine for you?Typical 70s ranch that was house wrapped 15 years ago. So not horribly drafty. The regency 3100 heated the house easily on 8 hour loading cycles untill single digits with high wind. The princess can't maintain temp well at 8 hours much under 20. It is entirely possible it doesn't matter how many times he loads it there may not be enough btus to heat the house untill it gets sealed up. Have you looked at the btu ratings? They are not all that high.
I was leant a princess to try. I will probably use something else next year. I typically change every 5 years or so. Or when I find a good deal on something I want to try. I still have the regency that might go back in. There is a quad I could stick in unless I find it a different home before then. We just got a pe dealer that I have a good relationship with so I may come across a good deal on one of them. I don't know.Why aren’t you using the regency anymore then since it did fine for you?
Hey fair enough! My wife thinks I’m nuts using too many different stoves lol! Told her I am just trying to narrow down to the perfect oneI was leant a princess to try. I will probably use something else next year. I typically change every 5 years or so. Or when I find a good deal on something I want to try. I still have the regency that might go back in. There is a quad I could stick in unless I find it a different home before then. We just got a pe dealer that I have a good relationship with so I may come across a good deal on one of them. I don't know.
The regency is the only other one I have used in this house on this chimney though so it is the only direct comparison I have.
