I am in the process of purchasing a home with all electric heat. As you can imagine the electric bills are quite high in the winter. So, I am looking for ideas. My current home has a forced air furnace supplemented by a Blaze King Princess stove. By burning wood, I have been able to keep my gas bills quite low over the last decade... roughly $50 max per month in the winter. I burn about 3 cords a year heating my 1100 sq. ft. home.
The home I'm purchasing is 1650 sq.ft and currently has electric resistive heat in the ceilings. I am leaning toward installing a natural gas forced air furnace of 90+% efficiency and supplementing with wood heat. We're on the fence as far as installing central air at the same time. I have entertained the following options.
1. Bring my Princess with me and locate it centrally in the house in conjunction with forced air heat.
2. Install an outdoor boiler in conjunction with a forced air furnace.
3. Install a boiler heating system with radiant heat tied in with an outdoor boiler.
4. Installing forced air furnace with an add on wood burning furnace.
Budget is a restriction... I figure on roughly $10k max. It could be done in stages... ie install the forced air furnace and use the BK for now. Then later add an outdoor boiler. The house currently has no ductwork, so it all has to be added. Also, the floors all need to be replaced down to the joists, so I assume this would be a good time to install ducts or radiant.
I will appreciate your $.02- Thanks
