woodburn said:...when air temps are below freezing, snow only evaporates if direct sunlight heats it to above freezing temps...
Not true: http://en.wikipedia.org/wiki/Sublimation_(chemistry)
woodburn said:Those are good points, especially about the underwear, but when air temps are below freezing, snow only evaporates if direct sunlight heats it to above freezing temps. Think about how quickly snow would evaporate on a July day. I think there's no comparison in how much the wood dries in summer as opposed to winter. Plus factor in the longer days with more sun. Of course, my piles are stacked in direct sun for the bulk of the day, so maybe one wouldn't notice quite as much of a difference if stacked in shade.
stanleyjohn said:Todd said:Depends on the weather. If it rains the tarps get rolled down, takes about 30 seconds. I leave them covered when the snow flies.
nice set up todd! what do you use for weight on the side you roll up!2by4 wood??.also how does to stand up to the wind?I may do the same with my outside wood piles,
11 Bravo said:Did it finally dry out in New England ? You folks were getting drenched ! We've had less than .50 " rain the past 35 days, so it's been excellent this summer for the wood here in W. Michigan
johnnywarm said:11 Bravo said:Did it finally dry out in New England ? You folks were getting drenched ! We've had less than .50 " rain the past 35 days, so it's been excellent this summer for the wood here in W. Michigan
Not a drop of rain in almost two weeks.
of course it can be done but is it woth it??? if you do do it i would suggest a fan running and to speed the process a dehumidfierjohnnywarm said:can you season split stacked wood in a garage?? how long do you think it would take to season??
John
iceman said:johnnywarm said:11 Bravo said:Did it finally dry out in New England ? You folks were getting drenched ! We've had less than .50 " rain the past 35 days, so it's been excellent this summer for the wood here in W. Michigan
you jinxed us tropical depression/storm headed thid way fri -sat all day
J-Man said:Johnny - Don't do it, I've made that mistake. Last year I stacked in my garage, and it didn't dry adequately. This year I'm seasoning outside, and it even looks 100% dryer than the wood seasoned an equal amount of time in the garage. It needs sun and air to dry, which you won't find in the garage. I plan on moving the wood into the garage in October.
iceman said:of course it can be done but is it woth it??? if you do do it i would suggest a fan running and to speed the process a dehumidfierjohnnywarm said:can you season split stacked wood in a garage?? how long do you think it would take to season??
John
johnnywarm said:well with 3 to 5"s coming Saturday its getting covered.i will remove it Sunday.
sonnyinbc said:To the op--do you cover your head when it rains? Whatever happened to common sense? :roll:
