I just purchased a Regency ci2700 wood stove insert. I was charged $700 for a 25 foot, 6 inch liner, 16"x16" plate, and cap. My installation is scheduled for next week. While setting up the install, I asked if the liner was insulated and the installer informed me it wasn't and that an insulated liner would be a lot more expensive and he doesn't typically recommend them for installations like mine in New Jersey. I currently have a stone/masonry fireplace with a 12" round clay flue liner and the chimney is on an interior wall.
I checked the installation manual and it says:
"In the U.S.A., a 5.5 inch (140 mm) or 6 inch (152 mm) diameter, stainless steel, full-height chimney liner that meets type HT (2100F) requirements per UL 1777 must be installed. The full liner must be attached to the insert flue collar and to the top of the existing masonry chimney. "
I don't know the manufacturer of the liner they're going to install so I'm not sure if it's rated up to 2100F. Should I insist on the use of an insulated liner?
![[Hearth.com] Do I need an insulated liner for a Regency ci2700 insert? [Hearth.com] Do I need an insulated liner for a Regency ci2700 insert?](https://www.hearth.com/talk/data/attachments/295/295365-2362237f70883ab5e0acd9cf48341f71.jpg?hash=lLON9a7i-_)
![[Hearth.com] Do I need an insulated liner for a Regency ci2700 insert? [Hearth.com] Do I need an insulated liner for a Regency ci2700 insert?](https://www.hearth.com/talk/data/attachments/295/295366-733e754b21663a7e3d21350bc59f088f.jpg?hash=2B69w8I81-)
