Hi all,
Apologies in advance for the long post but I think it best to give a detailed explanation up front.
I have just installed a new Drolet Escape 1800 and chimney system in a 1980 something manufactured home. Lit a few break in fires on cold mornings in the 30s. Fire burns fine with the door open but smolders with the door closed even after burning for thirty minutes. I can't close the door until it has almost reached the coaling stage. (Air intake open). When I close the door I get a few minutes of secondary flames then smolder. I know the recently split "seasoned" wood that I bought doesn't help but it's not much better with pallet wood or camp camp fire wood from Walmart. Stove pipe is double wall 5' 6" from stove top to ceiling box. 7" offset with elbows at the stove and ceiling creating a slight angle of about 15 degrees? 7' of chimney pipe from the ceiling box through the attic and roof. Cap is about 3' above ridge which is 7' away from chimney. I was thinking about adding another 2 or 3 ft of chimney pipe to see if that would help. I would appreciate suggestions.
Tony
Tony
![[Hearth.com] Draft issue? [Hearth.com] Draft issue?](https://www.hearth.com/talk/data/attachments/301/301395-1e035129b47a5ef91ce1a3093d77e0b0.jpg?hash=Tml8dQ6qpW)
