Good Day! I installed my Drolet 1800 insert, approx 23' insulated flexible liner, and key damper in the adapter last weekend (there's another thread with pics of the install). I did a couple small fires and it's basically been running ever since. Installed last Saturday with temps in the 50's- since then day time highs of around 30 and teens at night- perfect timing. Anyway I bought this stove with the intention of supplementing my furnace but now it seems to be an obsession to not let the furnace kick on. I'm new to stoves and need some help fine tuning/ running it efficiently. I seem to be tearing through my wood supply and I'm not sure I'm running this stove correctly.
At night time I do full e/w loads on hot coals. I leave the door cracked to get it going for about 15min. Then close door for about 15min then start cutting the air supply. Last night I hit 600 stove top temp with infrared gun and had an inferno going. After about 25min I was able to close the air supply fully with flames and secondary's still going. It was burning so good and hot that I had to throw 2-3 more pieces on before I went to bed- that was probably about 12am. Prior loads to that I know I've been shutting the door and attempting to damp it down way to early. Anyway I woke up at 5:30am to hot coals buried in ash with a stove temp of under 200. In the morning I only throw about 3 pieces on to get it going again because I don't have time to baby sit it for an hour and mess with a full load. Then through out the day I throw 2-3 pieces on at time. With that approach I can get stove top temps around 500-550 then they start dropping off. Should every load be a full load? I can't really do n/s loads at this time because the wood is too long.
I guess my main question is- is the ultimate goal to get the damper closed? Then at the same time how do I know if its damped down too much? Is no flames and and glowing logs acceptable? My glass is fairly clean except for the bottom corners. Then to throw another wrench in the mix is when do I mess with the key damper? I haven't even touched that yet- that's running wide open. Any info is appreciated.
![[Hearth.com] Drolet 1800 temps and overnight burns. [Hearth.com] Drolet 1800 temps and overnight burns.](https://www.hearth.com/talk/data/attachments/323/323290-189143c67c9b8aafae4ca8054cc7aae6.jpg?hash=-Ptk0P8ppS)
