Drolet vs Century Inserts
nal51511
6
CT
I am looking at the Drolet and Century Inserts and was wondering if there was difference between drolet and century to justify purchasing one versus the other? I am looking at the Drolet Escape 1500 or 1800 or the CW2100 or CW2900. It is for a 1500 square foot house in the shoreline of Connecticut so winters aren't very harsh and it just went through a full remodel with 2x6 walls walls and fiberglass insulation. any insight into any of the stoves is much appreciated, both should fit in the existing fire place but the larger inserts will be a tight fit.
thanks
Reactions: Easy Livin’ 3000
begreen
Mooderator
Staff member
Nov 18, 2005
98,851
South Puget Sound, WA
They are quite similar inside. The Century line is the basic line of SBI stoves, with Drolet being the value line, and Osburn being the flagship model.
EbS-P
4,232
SE North Carolina
Does it matter which way the door opens?? That’s probably the biggest difference between century and Drolet.
You don’t want 1.1 cu ft fire box of the cw2100. 4 hour burn time max.
I have the 1800 and am happy with it. I do at times which I had a more expensive looking insert but it’s in a basement that doesn’t get used all that much.
Easy Livin’ 3000
3,016
SEPA
thanks
Functionally identical. Get the one you like the looks/price of better. And I agree, go with the bigger model of either. You won't regret it.
Gearhead660
946
Southern WI
I have the CW2900, solid heater. No frills.
Check the dimensions and be sure the bigger insert will fit for certain.
