Drollet HT3000 , Blower AC02050
White Wagon
2
Nova Scotia
Hi everyone,
I have a Drolet HT3000 wood stove, second year with it. So far so good. Would anyone have the same type stove with the factory blower AC 02050 installed? I am considering purchasing the blower. I would like to know if it moves the heat well enough or am I just as well off to have a free standing fan moving the heat.
Thank you, any input is appreciated. Also, would it be worth it to purchase the Quick Connect Thermodisc, to control the on /off blower as per the the stove temperature?
Thanks.​
Mike
The blower definitely moves more heat because the air travels up across the hot stove back and then over the stove top. A drop in stove top temp when the blower is on will show this.
Reactions: Itslay90
I don't have the ht3000, but the Myriad II. Similar size stove. I got mine with the blower and thermodisc. I find the blower too loud, so I don't use it. It does help get more warm air out into the room.
If you run the stove 24/7, I don't think you would need the thermodisc. It's only useful if you plan to leave and let the stove go cold. My 2 cents...
Is this also true at low speed? The AC 02050 blower for the HT-3000 has a speed control rheostat. It's not silent, but should be fairly quiet on lower speeds. I thought that the Myriad II had the same rheostat.
We only use the blower on our stove when it needs to be pushed harder for heat due to outdoor temps in the teens or low 20s. It helps get the heat out to the farther corners of the first floor. Medium speed suffices in that case. I only run it on high to cool the stove down in a hurry because I let it get too hot.
The blower speed is adjustable. Low isnt that loud. I just prefer the silent heat of a stove. I only would use it if we needed the extra heat.
Going way back here, but I have a Drolet Baltic from 2008, and I bought the variable speed blower and thermodisc. I love the stove (except the firebox bricks only go up halfway inside, and it's bulged out on the sides due to warping, I guess, but you can only see that if you remove the heat shields from the sides), but I'm really disgusted with the blower.
My in-laws have an old stove from 1990 and the blower has never failed them, but you have to turn it on every evening, and it runs constantly until you shut it off. (We light our stoves late afternoon and put the last couple of logs on before going to sleep each night, and we let it go out - almost never close the intake)
So... I set the blower a little above the lowest setting for noise, and the thermodisc switches it on and off as the stove heats up and cools down - squirrel cage-style blower, all seems good in theory. So it was about $150-200 CAD if I remember correctly for the whole deal. 1 year warranty. It failed after about 13 months. Seriously. Needed a new rheostat. $50 CAD. Bought it and guess what? Failed again after 13 months. Bought an EcoFan (runs on heat converted into electrical energy - no batteries, no BS). Never had an issue with that. The blower would definitely be better because of the airflow, but SBI makes crap. Someone didn't allow for the ambient heat in their electrical design, or it was planned obsolescence at play.
I wouldn't mind making up my own fan setup with a simple fan and a duct.
