NickW
Yep. My experience is still going on with this. Last January I replaced my old smoke dragon with an EPA stove. Usually css in spring and burned it in fall, was able to make it work in the old stove. New one was a learning experience... The leftover ash from spring was OK, but by February I was trying to burn beech and hard maple css in fall. It can be done, but as stated by others it's a chore. Gotta get the heat up to get the moisture boiled out and minimize creosote before getting decent heat and by then you've burned up a lot of it.
This year I'm burning what's left of the oldest beech and maple along with softwood and ash css this spring. Pine is 16%, silver maple is 23%, Aspen is 17-22%, beech is mostly around 20% and hard maple is 22-23% and I sorted my way through the ash css in spring that is now the back stacks that is 18-24%. Not terrible #'s, but also not ideal - some fires go well and others are a struggle. Have it all in the garage with a fan on it to promote air flow to try to get it down some more. That ash was an interesting tree - trunk was 38% or higher and branches 28% or lower in spring. Mostly burning a mix of soft and hard right now.
I am in full gather and css mode. Will have enough css for next year already by the end of the week (ash, beech & aspen which season pretty well). Will be moving on to more for the next 2 years after that to get 3 years ahead. I've got access to some primo stuff - beech, hard maple, ash & oak. Have a little hickory & honey locust css for 2 years from now too. Softwoods are almost always readily available...
But, back to the subject... yes, wet wood sucks. Burn it hot and inspect the flue and cap regularly and clean it often; then do everything you can to get 2-3 years ahead.
