Encore 2040 CAT-C Blower Pics / details?
Turbo89
789
MA
I’m running a 2040 CAT-C in my shop and I’m interested in adding the blower assembly… but the new prices are crazy.
Does anyone have this or made something to replace it? It’s not clear how / where it mounts…. But is seems like one could easily attach a generic fan to it. I have lots of metal fab experience, so I could easily fabricate some sort of adapter.
I have one. It mounts on the bottom in the back, the switch is mounted right by the handle holder with a thermostat in the back as well. I find it to work very well. My stove is shoved in my hearth so it is very necessary. Its been there since initial install so I don't remember what it cost
Thanks! Do you think you could post pics of how it mounts and how the fan discharges?
The kits are like $450, so I’m thinking of making on; but would like to see how the air is routed and how it hangs.
I will but my stove is hot so its gonna be a few days. Not wanting to squeeze around it unless it's cold. My 220 lb self doesn't fit well in tight places
Reactions: Turbo89
I figured it may be with the cold front / potential snow up there today; we’re just a bit south of it, but it’s high 30s here now.
Thanks again!
Bump - cheapo, knock off $60 blower kit is supposed to show up in a few days. Hope to mount it before it’s too hot to burn.
Cheap fan kit unboxed, I’ll try to mount it this week, but may not get to it until wens night.
[Hearth.com] Encore 2040 CAT-C Blower Pics / details?
Reactions: Burnin Since 1991
Just installed the blower, here’s what I ended up doing, so if someone else wants to try:
First I had to re-clock the fan housing, the fans were clamped and glued in place. I use a lighter the loosen the glue and gently pried each fan off with a big pry bar:
It mounted in what I believe to be the factory location based on reading VC fan kit instructions, although I didn’t find the exact set for my CAT-C version:
Then I had to mark, tin snip and slightly bend the shield (VC says to do this for some versions in the fan install instructions):
Here it is installed, with my home made thermocouple mount back installed.
I’m going to temporarily wire it, and light it now to make sure it works. I’ll post back with results.
Fans working well, kicked on without a problem and is helping heat the shop more evenly. It sounds like a desktop computer fan, so it’s not too bad.
  • Haha
Reactions: Turbo89
Great thread. You lost me on re-clock the fan housing tho...
Fan housing had to be rotated 90º in order to point upward. Odd that the cages were glued to the shaft instead of being keyed and setscrewed.
This is spot on.
The glueing is become more common, they do the same thing in dryer fans… which suck equally bad to remove. I’m sure it’s because a dab of glue is cheaper than a key/shaft keyway.
