I'm hoping someone can help me. I recently got rid of my old smoke dragon airtight stove for one of those new EPA certified non-cat stoves. The problem I'm facing is that the fire goes out before it fully burns the wood at the back of the fire box. The fire will be going, I'll shut her down, and later when I go to rake the coals I'll find a piece at the back. Sometimes is half burned, most of the time it's just blackened.
I'm also having trouble on reloads, I'll rake the coals, put the wood in and the split sitting on the coals will just sit there and smolder for about 20 minutes before it finally goes, and then it takes forever for the fire to move past that initial split.
The only way I've found to get things to run like they should is to criss-cross my wood, which obviously cuts my burn time down.
I've been burning wood for 40 years, I just can't figure out this stove.
Am I just too old for this new technology?
-My wood is at ~20% and the stove and new pipe were professionally installed.-
It will improve slightly as the weather cools down as the draft will increase. You definitely wont be able to get long burns until the wood is optimal.
