Have you PM'd Mike yet on this board? He'll get you straightened out. Unfortunately, it's a bit of bad timing today and tomorrow with the Holidays and all.
I agree....looks lazy to me too. My guess is still airflow. I hope the outside OAK screen isn't clogged. We had a lot of wind here lately, and I had a leaf get stuck partially over the inlet....noticed a change in the stove right away. Same thing happened 2 yrs ago with a big snow storm.WOW....that flame looks huge to me if you are on a 1-4-1 setting on heat range 2.....the flame looks lazy too by my eye....well, like what's been said already it's either air flow or too many pellets being dumped in or both.....
I agree....looks lazy to me too. My guess is still airflow. I hope the outside OAK screen isn't clogged. We had a lot of wind here lately, and had a leaf get stuck partially over the inlet....noticed a change in the stove right away. Same thing happened 2 yrs ago with a big snow storm.
OK, good to know. Based on that video, it just seems like a very lazy flame.....that will cause a filled burn pot. I just don't know where to go with this anymore. As long as ALL the gaskets (door, ash pan, hopper, etc, etc) are all in good shape and are sealing correctly, the burn pot starts out clean, the stove is clean, and the combustion blower is running at the correct speed, I just don't see how it can do what it's doing.I checked the OAK just to be sure. No problem there. I also shortened it as well.
It's possible the board is bad....have you gone through the Englander board diagnostic procedure?
http://www.englanderstoves.com/help/PelletStove/diagnostic_mode04.html
The horizontal section of your vent still effectively exceeds the maximum allowable 4' of horizontal In fact all of your vent is horizontal and has a bend as well, as for that hooper lid gasket situation, it will also affect the air flow through the burn pot.
If your controller is in the wrong mode you can also be over feeding your stove, yours wouldn't be the first stove to have this situation.
I refer you to this post https://www.hearth.com/talk/threads/burn-pot-full-of-ash-in-my-55-trpep.101423/page-2#post-1305210 but it might be instructive to read the entire thread.
I asked Eric what Mike had him set the stove to in the other thread. Hope he responds.
I would agree with the hopper lid......
Dexter, I havent run through any diagnostics of the control board other than what the tech had be do. A whole bunch of button press sequences. He said my stove was set to the correct mode, which is #2.
Something I noticed today before I left to go to work. I cleaned out the stove and restarted it. But this time I started the stove at 2, instead of 3 or 4. I notice that the burn pot fills about a 1/4 to 1/2 way before it finally ignites across the entire pot. By setting it to 2, it still ignited, but there was much less material in the burn pot. By the time the stove came out of the start up sequence, there was a thin layer of hot ash at the bottom of the burnpot and a small flame that was barely to the bottom of the discharge shute. At this point I turned up the stove to 3. I decided to let it run for the day at this setting and will see what its like when I get home. Im thinking that maybe too much fuel builds up in the burnpot during start up and it never gets a chance to blow all the ash out? Who knows...
