brenndatomu
Well, guess that'd be alright if your house looked like this!Look at the up side, it could double as a whole home smoker!
Just wanted to include a quick clip of the smoke passing the bio damper
I haven’t, but can try tomorrow.
Right now, without the draft blower on and the stove running at full speed ahead, my draft meter reads 0.07.
So when you say “lower” the bark draft, are you suggesting to 0.04?
From what I have learned is that the baro meter measures negative pressure or a vacuum. The closer to “0”, the less draft from the stove. Therefore if I was to adjust lower, the less intake air is pulled into the stove when the blower is off.
Does this sound correct?
-0.04" would be a start...hafta play with it, see what works. And yes, the lower the number (closer to zero) the less "pull" on the stove. Thats why I said you would probably have to open the blower damper up some to run like this.So when you say “lower” the bark draft, are you suggesting to 0.04?
OK, one more from me then I don't think I have anything else to offer - are you sure your wood is dry?
Might have already been addressed and I missed it.
With the deep coal bed and ash, are there any passages that are plugged?
Its not back pressure you are dealing with...the fire is starving for air...and I can see why, that 3/8 gap is a TINY little hole for that size fire box to be breathing through! When the blower turns off, the fire now only gets air by what the chimney draft can pull through the intake...so it starves for air, the fire goes out, (the active flame) but the wood is still "burning" (smoldering) so the firebox fills with smoke (fuel) eventually the air/fuel mixture gets to the correct ratio to burn (explode) and there is already plenty of heat in there to ignite it so...BOOM!I simply don't understand why back pressure builds up as there is a clear path to the top chamber and then out the rear of the stove.
