What do you think about the Regency I3000L? There's one by me for $1500 new someone is selling. 2.9 cu ft firebox.
I think the 3000 is 2.3 cu ft.
The 3100 is 2.9 cu ft.
At least if I read the regency web site correctly.
That deflector has been replaced with a removable/replaceable heat deflector.There maybe a bit more room in front of the firebrick. 9" is just by the firebrick pattern. That is a good price, not much more than stoves 1/3d smaller and the stove by past reports heats even larger spaces quite well. IIRC about the only issue that has come up has been with the deflector. This got replaced with a better part a few years back. @bholler would know more. He cleans several of them.
If it will fit, the Osburn 2400 may be the most affordable large insert.
(broken link removed to https://www.osburn-mfg.com/en/products/wood-inserts/osburn-2400-wood-insert/)
Yes, I'm looking at that one, the CW2900 and the Drolet 1800i. The 2400 being the most expensive. My wife is not on board with spending anymore money on heating with wood so I'm searching every day for a good used one for around $500.
When looking at a used insert, any recommendation on what to look for? I understand firebricks, glass, gaskets etc. can be replaced and I've done that before what specifically the casing etc.
If you left your furnace on, the wood stove would probably carry 75% of the houses heating load, or more, no? Over the course of the average winter, maybe more like 90% if you include the warmer days where the furnace never runs?I tried the convection loop and it definitely helps however by the time the heat in the fireplace room is evenly distributed throughout the 2600 sq ft house it's turns out the whole house are 65, as opposed to the fireplace room being 85 and the bedrooms 58.
The 2400 is a third larger in real world capacity and can be loaded N/S. If the goal is to mostly heat with wood, go large. For inserts with a 6" flue collar that would be ~3.0 cu ft inserts made by Osburn (or Enerzone), Pacific Energy, Regency, Lopi (or Avalon), BK, Quadrafire.Yes, I'm looking at that one, the CW2900 and the Drolet 1800i. The 2400 being the most expensive. My wife is not on board with spending anymore money on heating with wood so I'm searching every day for a good used one for around $500.
Right. High BTU/hr ratings just indicate how fast you can burn through a load, but the best heat extraction occurs at low burn rates. High burns send heat up the flue.Firebox size isn't a measure of btu/hr output. It's just the size of the fuel tank - or total btu capacity. Not all stoves can burn that load at the same rate or put all that heat output into the house.
It's said that higher-priced inserts extract heat better, but I'm not sure how that works. At any rate, I would buy a higher-quality unit rather than buying a cheapie and getting low resale value. Not to mention that higher-priced units generally give you less problems. You have to also decide what features of a stove are worth to you, such as ash-handling etc.Or was it a US stove, or other subpar insert?
No kidding? So did I for a few years. I’m now over by independence lake.I used to live on Garfield Dr. in Whitmore Lake, Michigan.
So I found an Osburn 2400 for sale, person is asking $500 firm I'm picking up next Sunday.
Cool!It's about a 10 hour round trip but I'll be taking my 6 year old son and my dad in my truck so it should be a fun time.
Yes, I lived there for about 3 years 8900 Garfield Dr. from 2005-2008. I used to live in Brighton, then moved to New Hudson then ultimately Ypsilanti Township, south of 94 until I moved back to Indiana in 2016. I worked at Beaumont Hospital for years. I'm originally from Columbus Indiana so moved back home in 2016. Small world, I miss the cold and snow of Michigan! In Indiana it gets cold, but not as much snow.
The goal is tocompletely heat my house with wood. Keep the thermostat at 65 then rarely have it turn on as long as someone is maintaining the insert. We actually did have a energy efficiency company come out and assess our house. The only thing they advised was adding another 12 inches of blown in insulation in the attic and suggesting caulking around the exterior of the house/windows are it's starting to deteriorate. I plan on painting the house this summer anyways so I'll do that. Our windows are fine they said. They're the original Anderson ones from 1994 when the house was built so I guess they're good quality.
So I found an Osburn 2400 for sale, person is asking $500 firm I'm picking up next Sunday. It was made in 10/2009 she said. Has the blower and faceplate, everything. I wanted to pick it up this weekend but she's not available but she said she would save it for me. I'm super excited. It's about a 10 hour round trip but I'll be taking my 6 year old son and my dad in my truck so it should be a fun time. I assume that date of manufacture is just as good as the newer ones?
I lived on Garfield from 09-11. I grew up in New Hudson. Lived in a few different places in Ypsilanti while kind of going to eastern university. My parents now live in Brighton. Small world indeed. Hope your road trip is a success. Happy burning.Yes, I lived there for about 3 years 8900 Garfield Dr. from 2005-2008. I used to live in Brighton, then moved to New Hudson then ultimately Ypsilanti Township, south of 94 until I moved back to Indiana in 2016. I worked at Beaumont Hospital for years. I'm originally from Columbus Indiana so moved back home in 2016. Small world, I miss the cold and snow of Michigan! In Indiana it gets cold, but not as much snow.
Try to get lots of pics before that kind of drive.
How are you going to move it?
.... We actually did have a energy efficiency company come out and assess our house. The only thing they advised was adding another 12 inches of blown in insulation in the attic and suggesting caulking ...
If they didn't do a blower door test, you need another audit. Here, attic insulation is paid for 100%.
Sent from my SM-G950U using Tapatalk
No, they didn't do a blower door/vacuum test. What do you mean attic insulation is paid for 100%? I don't think Indiana has anything like that!
