Hi, I am trying to decide on a fireplace for my cabin. I am expanding and remodeling such that the finished living space will be less than 1200 sqft and the new insulation will be that expanding foam, so the sturcure will be fairly air tight. The fireplace will be in the new living area which itself is about 450 sqft floor space with 10 foot walls and added vaulted ceiling. The fireplace will be centered on a 16 foot wide wall and the stone around the fireplace will go up the 10 wall and the additional 8 feet or so up to the vaulted ceiling pinnacle.
I like the 44 as it will have the Artisan face and double doors.....so it will look good when not fired. after all, in Texas, most of the time it is just a fixture.
In Texas, I will most likely use the fireplace less than 14 days a year and I am really not that concerned about the heat output, but more so the asthetics...I like a true woodburning fireplace. I have been told because of the air tightness of the structure, that a conventional fireplace that pulls air from the living space will not operate very well...smoke in the house and such. So the FPX has been recommeded as it pulls air from the outside and is pretty much self contained when the doors are closed.
So my question is, as I know the 44 is way oversized for the space, but with all the controls, will the 44 burn ok? Even turning down the controls for minimum heat blowing in the room?
Thanks in advance for the comments.....
