I need some advice on making changes to the drainage in front of our garage door.
Our gravel driveway slopes a little bit towards the garage - not much and unless it's a lot of rain it usually soaks in before running too far. There is a drain system, with two small, round drains (one on each end of the garage door) and some concrete that mostly slopes towards them. This may have been put in in 1962 when the house was built, or perhaps added later. The drains connect to 5" cast iron pipe that runs about 20 ft out the side of the hill. As poor as this is, it works pretty well unless we get a real downpour or there's a lot of leaves on the ground - then the garage floods. It's finally time to fix that.
I'm thinking about buying a pre-formed trench, digging out the old system - cast iron pipe and all - the laying in the trench. I will then pour concrete around the trench, up to the garage floor on one side and 6" or so towards the gravel on the other, and slope that towards the drain. I plan to either lay a new drain pipe out the side of the hill or connect to what's already in the ground.
Any advice or thoughts from those who've done this would be great! Specifically:
Thanks!
- What do you think of the overall plan?
- Brands or sources for a pre-made trench? I've seen a lot on the internet, but it's mostly aimed at contractors, not DIYers.
- Do I need to pour concrete under the drain, or just put down gravel?
- What about connecting to the current drain pipe? It would save a LOT of digging, but are there concerns?
Thanks!
