If you have dry wood, a good draft, a good coal bed, and you burn 24-7 due to colder temps it will easily be able to keep the house warm.
My experience this year, when the temps are between 10-32
I am easily able to keep a 2000 sq ft house above 75
note I am heating the house from my block basement.
When the temps are between -20 and 0
I am able to keep it around 72
When the temps are between -40 and -21
I am able to keep it around 68
I can go around 6-10 hours without refilling using softwood, and 12-18 hours using hardwood (depending on how much heat I need)
A) If you have poorly seasoned wood and a good draft, you can with modifying your operating procedures get the low end on the burn times with enough heat to heat your home.
B) If you do not have a good draft but you do have seasoned wood <20%, you can with modifying your operating procedures get the low end on the burn times with enough heat to heat your home.
C) If you have poorly seasoned wood and a poor draft, you will not get those burn times, you will not get the heat, and you will gunk up your chimney.
D) If you have a good draft and seasoned wood -20%, on a good coal bed the high end burn times can be obtained.
My low end burn times were associated with A, my high end burn times were associated with D.
I had this stove for around 6 years.
