Harman P61 Esp light on fan on full
I'm going to assume that the internal thermometer and the one on the table are not reading the same. I'll see how long it lasts.
It almost went out so I turned the ignitor to manual and it started up again. It barely started. So I'll see what happens now. It's still above the set temp but maybe it will just reduce the feed rate. I turned the feed rate down to 3. It's pouring pellets out again and it's 3 degrees above the set point. Can I assume the internal thermometer is off and turn the temperature down to 70 it's piling the heat on again. I turned it down to 70 and it's still pouring the heat out.
Still pouring out the heat.
[Hearth.com] Harman P61 Esp light on fan on full
I've also noted the combustion blower light is off and it's just barely running.
And the house hasn't warmered up a degree, it's was 40 outside and 72 in here, at 530 am it's now 50 outside and the same temp inside at 920 am. Bright and sunny
Blower doesn't come on unless I put the ignitor switch to ignite, is that what it should be doing?
Is it going to pump all these pellets through it all day until it drops to below 70 or whatever I set it at? It hasn't slowed the feed rate down.
Checked the temperature at the external sensor still at 78. It's still pumping a lot of pellets throught it. I turned it off and on to see if it slowed down the feed. At this rate it will cook me out of the house. Inside temps are now rising.
Unplugged the external sensor and the status light came on so it's working. Still pumping out a lot of heat, going to have to turn it off soon. Not impressed.
I turned it back to ignitor on and the status light went out meaning it's shutting down and i assume it's going to shut itself off, like before, which isn't what I wanted
