Hello everyone. New guy here looking for opinions. I've been heating with wood my whole life and currently am heating my smallish 1400 square foot ranch with an Avalon Ranier insert. It's provided 90% of my heat for the last 9-10 years. I am building a new home in the spring and would like to get the wood, ash, and smoke from my LR to the basement. The new home will have gas forced air and because it is new construction, I will have my HVAC guy there to tie everything in at once. I have been researching add on furnaces for a while and have my choices narrowed down to two. The Harmon SF-1500-A or the Englander 28-3500. The Harmon because it is the only highly rated furnace sold locally and the Englander because... well... I can have it shipped to my door for $1240... I have read good things about both here and elsewhere but don't know what would be the best choice for my installation. I live in MA and the home will be approx. 2200 square feet, two stories, and very well insulated. I am looking to use the wood furnace for 90% of my heat again, only using the gas in the warmer transitional months and while we are away on winter vacations. I would also enjoy warmer floors with the fire in the basement. The advantages of the Harmon are auto draft control, larger blower, optional DHW coil, and full size 20X20 plenum. The Englander has a great price and seems simple in operation and installation. It's not about the money though as I really just want what's best for the house. So, here are my questions:
1) Does anyone bother to tie in to the homes cold air return ducts or are people just using the basement air for supply? (Also, can the cold air return be tapped for the two models I'm considering?)
2) The Harmon is rated at 90k BTU and 2200 square feet. The Englander is rated at 80k BTU's and 3000 square feet. Are they calculating different because the lower BTU rated unit is listed as being able to heat more square feet??
3) Will the auto damper of the Harmon give me a longer burn time? Also, will it cause more creosote build up slowing down the burn when the thermostat is not calling for heat?
4) I have read that the Englander's older style design uses more wood than other designs. It is only rated at 63. Will I be using a great deal more wood with the Englander than the Harmon?
I'll probably have more questions but I didn't want to get too overwhelming on my first post. Thanks in advance for any thoughts or opinions!!
PS: In case anyone is interested, the Harmon is about $2700 and the Englander is $1240.
I guess I need to look at the Caddy further. Less wood, glass door, and auto damper. Seems like the best of both worlds. Plus I can buy the one without the blower and just use the blower on my existing gas furnace. Might be just the ticket. Thanks for the ideas!
