:cheese: Greetings to all, newcomer to the forum. I am happy to say that I have learned a lot here. I have been researching these two for a couple years. I'm getting ready to make my move.
The house currently has an Avalon steel hearth stove mounted on a mica hearthpad in front of a pre-fab metal, zero clearance fireplace. It has a 32' ten inch round double wall chimney with a wood framed chase on the south side (outside) wall. It also has a six inch stainless liner inside the ten inch with a cap and cleanout tee.
The house is 1700 sq ' two story with crawl space. It has lots of large windows and was very expensive to keep warm until I installed some magnetic interior windows last winter. Now the house heats up ok. This summer I'm installing a new ceiling fan above the stairs. The existing stove is 1985 vintage and needless to say not all that efficient. The house is well insulated and now fairly air tight. I want to get a new certified non-cat stove that will use less fuel with the same heat.
The draft is fairly strong, but sometimes it's hard to get a fire to stay lit once started. I have been burning one year leftover cord wood and press logs. Last year only press logs. There is not much hardwood out here in the northwest (Seattle). Mostly fir, cedar, alder and some maple.
Between the two, I wonder which one will be easiest to start? I suspect the Jotul. I'm leaning toward the homestead from all the good things I've read about soapstone. It would be nice to avoid being roasted out of the room with the Jotul. I really like the smooth even temp of the soapstone. Both are outstanding and beautiful stoves. However neither one is without it's problems. I read about the hearthstones having some air sealing problems. I still really like the Jotul though. They've been making stoves much longer than hearthstone. In the end I suppose it's up to the big boss (wife) she likes the Jotul. All feedback considered. Thanks, holysmokers
