Hi All, new to the forum.  Thanks for having me.
I'm a new owner of a Heatmaster C-375, burning wood. I'm new to this furnace, but not OWB, it replaced a CB 6048 that I had for 14 years. This C-375 looks like a good unit, well built and very happy with it, except I can't keep the fire going. It's heating my shop and it is cooling off here in eastern PA so I should have enough of a heat load to keep this thing going, but I can't.
I have called my dealer and discussed with him, I have called Heatmaster and discussed with them. I'm told I've done everything correctly, but obviously not, hopefully I can get some help here. So here's the story; It should be as simple as build a fire, keep wood in it. I started with a differential of 10 degrees and high limit of 180. I'm burning red oak that has been split and dry for 2 years along with some dead ash, but mostly oak. My splits are 4 to 6 inch size with some 8 to 10 inch all about 18" long. Once the water is up to temperature, the furnace shuts down and does not restart. I left the house this morning with and the furnace was hot. I went home at lunch to check on it, temp was at 155, blower running and no fire, lots of wood and charcoal.
I have tried every combination I can think of for differentials from 2 degrees to 10 degrees and high limit from 180 down to 165. I have loaded wood all the same direction, different directions, in the front of the box, back of the box, on the side. Mixed wood large and small, all large, all small, keep the ash pan clean, etc. I can't figure it out - it shouldn't be this hard. There isn't an air flow problem when the blower is running, plenty of air, maybe too much. I don't think I'm hitting the high limit that shuts down the furnace since the fan is always on, and I've never seen the temp over 183.
The only helpful information I got was from the corporate office. There is a small hole below the fan with a flap on it to allow air into the firebox between burns. This isn't shown in the manual, and it was closed. Once I opened that, it burned for 2 days with no issue and then back to normal, no restarts. He also suggested a lever on the bottom that limits air flow into the box, but my unit doesn't have that.
When I open the door and it's out, there is plenty of wood, but no coals, lots of charcoal, but large pieces.
I'm not here to bash the dealer or manufacturer, just trying to figure this out. The manufacturer has a good reputation based on the reviews I've read. I also realize they market this as a coal furnace. According to the dealer and person I talked to at corporate it is identical to the MF series that is rated for wood. It shouldn't be this hard.
Thanks for any help you can give. I'm open to any suggestions, I really want this to work.
Jim
Jim
