G400 shows 89”
I’m trying to figure out if I have room for a g400 down there.
I believe there is a minimum space between top of unit and the ceiling above it?
Thanks
Not sure what the turbs look like...they might flex enough to be able to get them out with a low ceiling height?You'd want space the length of the heat exchange tubes (48"+) in case you ever need to pull the turbulators.
That sounds pretty tight.
Not sure on the 15' maximum. Yes chimney specs are usually draft related, but exceeding a max height I would think would lead to too much draft, which you should be able to regulate with a barometric damper. I would call Heatmaster on that.
And the 6" top clearance just looks like a simple combustion surface requirement - it might not have anything to do with the practicality of pulling turbs. So I would still go see one in person on that.
I just do outdoor installs but I would think the 15' max is to control the draft as was mentioned.
The turbs are twisted stainless and are pretty stiff. On a G400 I'd like at least 6' to have room to work if needed.
Any chance of putting it outside? Maybe with a woodshed beside it?
No way to get a trap door in the floor/ceiling over that spot is there? Might be relatively easy with conventional wood framing, but I am clueless on what the concrete would mean for that.
Yes, OK - that might not be good then. Insurance might not like any holes at all in the floor. Actually, are you sure they are OK with a wood burner down there regardless of holes in floor? The stairway could also be seen as a hole in the floor too, maybe. I think that (vehicles above) may turn out to be a bigger can of worms, with further thought. Even with the factory legs, I am not sure the firebox would be far enough off the floor, for what I have read their requirements are for a garage situation - if they allow it at all.
The one guy to speak to who really counts though is your insurance guy. I wouldn't want to find out I created an uninsurable situation, after investing big in it. Quite a bit at stake.
This is a pretty unique situation.
Stepping back to get a better view.
As to the items above:
- Do you have natural gas available?
- What will be your source for firewood over the next 10 or 20 years?
- Are you aware of the firewood quality requirements dictated by a gasification boiler?
- What will be the primary heating system for the entire house after the addition?
- Why is this particular unit (G series) your choice?
- At this point in time, from a financial perspective, the best way to go. It appears to hold the top spot for some time, but we never know for sure.
- Some areas are better suited to using firewood than others. Do you have wooded acreage at this home?
- For optimum gains the firewood must be below 20% and closer to 15%. It takes time to season or more money to purchase than green firewood. Generally speaking gasificatioin boilers use smaller splits than wood stoves and considerably smaller than what are used in conventional outdoor wood heaters.
- Natural gas? If ya have that, what the heck are you thinking?
- One quick note about the G series. The statement in the brochure, "The EZ Clean handle makes cleaning the heat exchange tubes a breeze." has proven ineffective at best, and actually counter productive to getting a good transfer of heat. This may not be the type of heating unit best suited to your situation. I will assume from the square footage that this is a higher end home and you will not be skimping on insulation. What may happen, especially considering such a tall chimney and good insulation, you will have creosote issues due to idling. Gasification boilers are best suited to systems with thermal storage where batch burn recharge is implemented, no idling equals no creosote.
1. No, I wish. I live rurally and natural gas is not available.
2. I live on 12 acres of wooded area and my Dad is a couple miles away on 80. I grew up helping my dad get firewood as that was his primary means of heating the home I was raised in.
3. I understand this. I prefer burning red elm because after the tree dies it basically seasons while standing up because there is no bark on the tree, and finally falls to the ground with low moisture content. I also understand that I will most likely have to purchase and have firewood delivered during times when my occupation doesn’t allow me the time to get it myself. That being said, I enjoy gathering it myself and consider it a great excuse to get outside and get some exercise.
4. I’d like for wood to be the primary source. But the radiant system will be hooked to my backup source of fuel, propane, which will have its own boiler. Reference my other thread below, “Finalizing Plans / Seeking Advice” - I attached the building docs here. https://www.hearth.com/talk/threads/finalizing-plans-advice.171331/
5. This unit was recommended by a few people, and I was attracted to a boiler with integral water storage. Do you have a different recommendation for this setup?
- Yeah it's a wish here too.
- Nice not having to purchase for sure.
- Glad you have considered this aspect.
- WOW. Didn't look at your other thread yet but WOW to firewood as primary heat for 7600 square feet. You will have a heat loss analysis done, yes? It is going to be a lot of btu's, meaning it is going to be a lot of firewood. Talking a dozen full cords with an efficient system.
- Be advised, I am by no means a professional HVAC person. Garn seems to me a better fit to your demands, or maybe a pellet system. Some of the pellet boilers are claiming 90% efficiency. Much less creosote concerns with the pellet boilers, but pellets are not free like cutting from your woods. Since you have acreage maybe another wing where your overhead door is for a boiler and storage room. Hey it's easy for me to spend your money, lol.
Have you looked at Switzer?
