House Circulation Issue
andycee
4
Cape Cod
Hey folks, long-time lurker, first-time poster here. We had a Regency CI2700 wood insert installed this summer, after loads of research (and because the Blaze King we wanted would have required major work to our fireplace), and while I'm starting to get comfortable with managing the fireplace and getting decent burn time (I got my first fire to start this morning without having to use a lighter-- just the embers from last night), but I'm still challenged by the air circulation issue. I've done a bit of reading, but our house is a very unique layout.
Anyone familiar with New England has seen a version of my house a million times-- the classic colonial with the bonus room on the side with the fireplace at the far end. However, the interior layout has the stairwell on the opposite end of the house, making it difficult to get the heat to flow upstairs. We have mini splits throughout the house (in the image below, they are the red rectangles) and we have a ceiling fan in the vaulted bonus room (the brown circle). Every bedroom on the second floor has a minisplit, so a layout of the rooms isn't really helpful I don't think. Currently, I'm running about 80-82 in the bonus room, 72ish next to the bottom of the stairwell, and mid/high 60s in the upstairs.
So, yeah, there's room for improvement. I've got the ceiling fan running low counter-clockwise and the splits running on fan mode. I know the choke where the bathroom is probably is the reason for the inability for the air to move, but I'm not sure what to do. I would put some small fans in the ceiling corner, but there aren't any outlets, and with two small kids, I'd rather not run extension cables (nor would I want to look at it for 6 months a year). I've considered cutting a vent hole in my daughter's room, which butts against the vaulted ceiling of the bonus room, but I'd like to save that for a last resort. Any thoughts would be greatly appreciated!
[Hearth.com] House Circulation Issue
That is long way for an insert to get heat to, I'd wait a couple more weeks and let some longer cold set in first to see if any thermal loops set in. There is a possibility that the insert may just be a heat saver (supplemental) to more substantial heating by mechanical means.
There is a way to do something but it maybe ugly, you can cut in a cold air return vent and install 18" shrouds on it to funnel the air down past the warmest air on the ceiling (its an old new England trick) but again it might be a waste of time also since your insert is flush mounted so you will have limited heat coming out between optimal heating periods when the blower is running (burn cycle) by any chance did you also have an insulated block off plate installed before the unit was slid into place?
Back in the day when dinosaurs roamed the Earth and before forced air Heat. Convection heat was used.. my brother has an old farm house with 2.5x3 ft grates in the floors alowing the heater in the basement to heat the 2 floors above it.. this would allow a portion of that air to go right upstairs .. this would help creat the loop you need
Reactions: jotulguy
As you've figured out the vaulted ceiling and long path to the upstairs stairway is not a great setup. Cutting a vent into the upstairs bedroom would help, but that would only serve one bedroom if the door is closed. Is there a basement? If so that might be useful for locating a duct to pull cold air descending down the stairwell and push it to the bonus room.
Thanks for the feedback-- we did not have an insulated block installed. I was going to , but I felt like there were some folks adament that it was a bad idea and the installer didn't recommend it.
My biggest concern with the vent is whether or not there's a loss of privacy for my daughter. We generally don't close doors in the house, so it shouldn't be a problem.
We leave our basement door open for the cats; the basement door is in the middle of the house, so I'm not sure if that's really helpful. Are you suggesting putting a vent in the bonus room into the basement?
Our thought when we put the wood stove in was that since it can handle 2800 square feet, our 1800 sq ft house, albeit not the ideal layout, would be able to heated by the stove-- at least about 80% of the heat. I don't mind the bonus room running 5, even 10 degrees warmer than the rest of the house, as long as the rest of the house warms up. Right now it's hard to tell how much of an impact it's having on the upstairs-- I guess we will have to see if the colder weather helps create better thermal loops.
You might be taking a fair hit from the absence of an insulated block off plate.
EDIT: And, square footage stove heating capability 'specs' is some darn fuzzy stuff...
Yeah, the specs I figured were a bloated number, hence why I got a bigger stove than we 'needed'.
I was considering getting some rockwool behind it at some point-- Seems like an easy, albeit heavy, thing to add. I was on the fence about it because our garage is on the other side of the chimney, so if there's a bit of heat loss in there, it's not a total loss.
Also, I found a fan in our basement that I stuck in the corner of the kitchen, but I'm not sure which way makes more sense to face. Should it face towards the stairwell, or towards the mini split in our dining room? Also, I've seen folks say to keep ceiling fans on a low setting-- is that the same for floor/counter fans?
Thanks again.
Not having a block off plate could cause you to be losing lots of heat up and then out thru the chimney - most of which likely wouldn't end up in the garage. (A guess, without knowing entire chimney construction and seeing your chimney/garage relationship).
Not sure on orientation of fans - that's a very hamstrung floor plan for trying to get heat to circulate around. Lots of turns & obstacles. You might need more than one to see any difference. Or resort to cutting a hole, which I would be very reluctant to do. And not sure cutting holes in floors/ceilings for that would be legal or up to code - sometimes & some places, it isn't. I've been trying to figure the best way at my place the last bit to get more of our mini-split heat into the far end of our kitchen. Think I will start by getting a fan I can hang in the top corner of a doorway and see what that does.
I have pondered this before because my laundry room always stays much colder than rest of house. I wondered if cutting a vent hole at top of wall and placing a crawl space vent fan in it would work. Reluctant as well to do this if the results happen to be negligible. My grandparents house use to have these vents in rooms that stayed cold but i cant say as to how well they worked since i was so young.
I'm guessing if you remember them having the vents in the room because they stayed cold, they probably didn't work, or you wouldn't remember them as the rooms that stayed cold. Probably better than otherwise, though.
I guess i worded that wrong. I dont rememember if rooms stayed cold or warm. They had the vents in rooms that were blocked from stove room by wall. I guess all i remember is standing on headboard and watching gpa watch john wayne movies when i was suppose to be sleeping lol.;) I cant imagine them working well without something aiding in moving the warm air at ceiling unless it just had to move straight up instead of sideways. Not trying to hijack thread just curious if that would help op as well as me.
I just re-read a bit. Sounds like your daughters upstairs bedroom shares its wall or part of it with the top part of the great room wall? Vaulted ceiling in the great room?
I'm not keen on cutting holes in walls or ceilings (which is what I had been thinking - ceiling), but I am thinking that if a hole is to be cut, it would be somewhere on that wall, at the top of the great room wall, and then the ceiling fan below might be enough to establish a loop of moving air by pulling air down from the ceiling and thru the new hole, and getting air to move down then across to the other end of the house then up the stairs back to the hole.
Hard to see everything from here though.
One thing a lot of folks do not think about is if they optimizing heat flow for heating, they are optimizing smoke and fire flow. Cutting holes in walls and floors can cut crucial minutes for escape time from a house fire. There are spring loaded dampers held open bya fusible link that can be purchased that would go inside the vents being cut that will allow the heat to be distributed but if there is fire, the link will melt and the dampers will close. These are required on commercial duct systems.
Each person has their heat preferences but if the coldest part of my house was in the upper 60s, I’d pat myself on the back and declare Mission Complete. I wouldn’t want bedrooms much higher than that anyway. Sleep better when the room is a little cooler.
80’s in the stove room is too hot for me. I’d even it out by throwing cool air into the room with a fan on the floor. Even a little bit will help with the circulation and by extension warm up the other rooms a few degrees.
fans are probably your best bet... FWIW my insert is in the basement which will be in the 70s when running, and the upstairs wont budge past low 60s, my heat kicks on the same as if there was no insert....you may be expecting too much from an insert? ouotside temps are low 30s
As a firefighter the thing with using a fusible damper is that your already done because the smoke will always precede the heat that would close the damper 10 fold, how many wood burners close all there bedroom doors at night while sleeping, or keep them closed all the time? A closed bedroom door can be the difference of keeping a fire contained to a room, or adding those extra few critical minutes for escape / rescue, but its impracticable for a wood burner to do that, especially when there trying to heat there home essentially from one large space heater.
Wood burners have to take a calculated risk to heat there homes, typical fire safety starts with planning, prevention, maintenance, and establishing proper practices.
I totally agree that cutting vents in floors is allowing a fire to travel easier, but if you follow prevention, maintenance and establish proper safety / operation of the stove you reduce your overall risk of having a fire in the first place, its a little bit of a catch 22.
So, yeah, there's room for improvement. I've got the ceiling fan running low counter-clockwise and the splits running on fan mode. I know the choke where the bathroom is probably is the reason for the inability for the air to move, but I'm not sure what to do. I would put some small fans in the ceiling corner, but there aren't any outlets, and with two small kids, I'd rather not run extension cables (nor would I want to look at it for 6 months a year). I've considered cutting a vent hole in my daughter's room, which butts against the vaulted ceiling of the bonus room, but I'd like to save that for a last resort. Any thoughts would be greatly appreciated!View attachment 250611
Andycee, I'm sorry I can't help you with the layout issues you are having but just moved into a house here in NC and there is a very large fireplace which had a propane heater set up but was removed, however the flu pipe remains and I was considering purchasing the Regency CI2700 and wanted to know what you think of it and if you don't mind, what it cost you? I believe it would be a very easy install because the flu pipe is there and it would just be a matter of cutting the size out of the firebox plate and connecting it to the 7" pipe. I like the modern look of the CI2700 as it is modern looking. Not sure why most of the wood stove companies think everyone lives in a log cabin and needs to design their product to look old and antique. I love the contemporary look of the Regency CI2700 and it is the largest one they have which would fit nicely into my large fireplace.
