BIGChrisNH
Mid 70's is nice and comfortable for us, then the second floor is low 70's. So sleeping is more comfortable/not too warm
Lol. My wife did the fire this morning when it was pretty cool in the house and overdid it, as I've done too sometimes. It got up to about 78 in here. Oh well, it's only wood, right?Usually around 71F in the house and ~73F in the living room where the stove is. Last night I messed up. Daytime temps were 47F and falling by evening so I reloaded with 6 large splits. That was a mistake. A system blew in and temperatures outside started to rise. By 9pm it was 76F in the living room and I was down to a t shirt. I slept with just a sheet for a cover. It was 52F outside at 6am.
No. Around here, windows are to allow wind-blown rain in.Isn't that what windows are for?
Getting walloped right now?No. Around here, windows are to allow wind-blown rain in.
I've never seen so much standing water in places that normally drain off or drain down right away.Getting walloped right now?
I havent received any US news but watching the Vancouver BC news on global 85,000 folks were without power this morning. Im much further inland as you know but we woke up to 4 inches of sloppy snow but no storm activity. Hope you dont flood!I've never seen so much standing water in places that normally drain off or drain down right away.
Flooding under these conditions is always a concern around here, but mostly in the lower river areas. We're fortunate to be in a higher elevation without those problems.Hope you dont flood!
Just to show how fickle this wx has been, I was just outside gathering some cut rounds and it was sunny and warm. That water is gone now, but I had a 3-gal size orange bucket by the chicken coop that was empty a couple days ago and is now full. About nine inches.I've never seen so much standing water in places that normally drain off or drain down right away.
Yeah, that's kind of hard to believe unless it were night time temps. What are the heating fuel options over there?I also stumbled across a claim by the BBC that in the UK the average thermostat setting is 63.5, and bedrooms are kept around 57, but from my visits over there, my impression is in reality they usually set thermostats in the 68-70 range like we do.
I like that reply. There really is a lot of psychological factor in this. I've always been amused that on a cold blustery wet winter day, 80 can feel nice and toasty and on a hot summer day we will have the A/C turned to 75 or less and still feel a bit too warm.Its usually between 80 and 90 in the living room and depending on the temp outside it can feel too hot or feel just right.
You probably get real cranky when the temp sores to 72.7 I bet.72.6 degrees F.
This seems to be pretty typical (or average at least). All these responses show that every body is different and every home is different and every climate makes for different results.Our room with the stove runs about 75-78. Each room away drops about 5 degrees. The back side of the house and the hardest to heat runs about 60-62 unless it is bitter cold outside.
I like the low to mid 70's regardless of the time of year...just can do without humidity.
I found what seems to work the best but given the odd layout of the entrances to our stove room, it takes a while. I had some good success using 2 fans instead of one. One fan blowing air out of the room and a second down the hallway creating cross-breeze of sorts. The wifey disagrees and has a method she thinks works better but the temps are not any warmer and the room with the stove drops 4 degrees. First year with the stove so I have time to figure it out....and convince the wifey.As regards to heating peripheral rooms, I've found it quite useful, if counterintuitive, to place a small fan at the door of a bedroom, for example, and blow it outwards. It blows the cool air out into the heated area and causes the warmer air to replace it above. Again, though, it depends on the layout.
That's right. It takes some experimentation because every layout is different. All you can do is learn the basics of what you want to accomplish, listen to others' experiences and do whatever works for you.First year with the stove so I have time to figure it out....and convince the wifey.
How many thermometers have you got? What if they don't all agree??72.6 degrees F.
