If you are anything like me you have family members that enjoy a nice warm and pretty fire like we do but they also aren't reading hearth.com and trying to get the stove working at optimum efficiency. They are not going to crouch in front of the glass looking up at the secondaries to decide whether the primary are should be closed at 10% or 11.5%.
Sometimes these people are running the shop when you're away and need to be responsible. I'm finding I need to do a little training for mine. I want my instructions to be easy to remember and don't make me seem like a condescending ahole. Here's what I'm thinking to prevent coming home to a smouldering smoke filled firebox or an inferno. These aren't exactly how I would do it but I'm more worried about safety and will sacrifice some efficiency for it.
Starting from cold.
- Load n/s except for kindling on top.
- kindling is anything thinner than 1". Just because a piece is smaller than another one doesn't make it small.
- Make sure the wood is no higher than the brick
- check the temp every 10 minutes for an hour. Less than 400 = more air and less / no fan. More than 500 = less air and more fan.
- when turning it down always leave the primary air open at least a tiny smidge. Never shut it down all the way like that idiot husband / father of yours. You'll have to keep checking it later in the burn.
- The fire doesn't go out like a campfire. Glowing coals are good. If you like to see a little more flame than turn the air up a touch. Black wood with no flame is bad.
Reloading:
- Don't reload unless the temp is below 300.
- If you ignore me about the coals and you want a pretty flame when above 300 then a single small split e/w towards the front is acceptable.
- for a full reload do everything above except check the fire every 5 minutes for half an hour. Then every 10 minutes.
- You don't need to sit in front of the fire staring at it for two hours like your crazy husband / father who has better things to do but refuses to do them - but you should - especially if he's around to do it with you.
What do you think? Any instructions you give to your folks - anything serious or sarcastic is appreciated.
Cheers.
Starting from cold.
Reloading:
Cheers.
Get her/them to work. My wife is thin urban girl who's afraid of spiders etc. When my wood is processed I put it next to my pallets and she stacks it instead of going to gym. Since she is a neat freak my piles are beautiful .
