Hello Hearth Friends,
I spent a lot of time on this site about a year ago trying to figure out how to get a decent stove or insert into my very small fireplace with close mantel. After much helpful advice, two people coming out to my house to check out the fireplace, debating if I should remove my 1890s mantel, etc. I finally threw in the towel and accepted that I wasn't going to be able to get any sort of stove or insert into my fireplace that would heat my close to 2000 square foot house (not even the smallest inserts would meet my clearances or shallow depth).
I was almost resined to just lining my chimney (it's currently unlined) and using the fireplace for regular fires which will look nice and give me little to no heat. As we are now in the dead of winter and our first floor is the coldest part of our house, I'm considering a new option. With a mantel shield and double walled pipe, I can probably just fit a Jotul f100. I know this won't come close to heating my whole house or giving overnight burns, but I'm wondering if it would be make sense to heat the first floor of my house, cut back on the use of the furnace (we have natural gas), and allow us to just be warmer on the first floor (where we're often at about 67 degrees). Our first floor is about 750 square feet, second floor is about the same and the third floor is about 500 square feet. We have a partially open floor plan. I was thinking that I could close the heat registers on the first floor when using the stove, but I'm concerned that with the heat from the f100 dissipating throughout the house and not making much of a difference.
I'd love some thoughts from all the insightful and knowledgable people here. As a side note, it will cost about $3000 to line my chimney for open fires, and probably less for a good used f100 with insulated liner installed.
Thanks!
Kenny
Thanks!
Kenny
![[Hearth.com] Is the Jotul F100 worth it for my small fireplace but large house? [Hearth.com] Is the Jotul F100 worth it for my small fireplace but large house?](https://www.hearth.com/talk/data/attachments/139/139259-51b47afd844642b200b8824678e2b84c.jpg?hash=4WKmBu7CuK)
You got plenty of dry wood, right?
