Well, one can only do what one can do.  Like I said, it is hard to get two seasons ahead with a stove that consumes this much wood.  Gonna give it a try, however.  I should have a good bit left over after this winter unless we get a run of really cold weather.  Still I have to say, I've burned wood exactly like this for the past 25 years in three other stoves with no trouble.  I'm willing to grant that this new stove will take some adjustment, some getting used to.  But had I been able to find real detailed reviews before I bought it I probably would have gone a different direction.  No matter, it's what I have now and there's no way I can afford another stove, so I have to make this one work.  I would point out that Jotul says it is a whole house heater, capable of heating 1800sf, which is what I'm trying to heat with it.  Based on what some other folks here have said, that's a bit of an exaggeration.  So far I'd give it a B-.  We'll see if dryer wood improves it.  Doesn't seem like I should have to get into complicated modifications just to get it to do what it ought to do as designed and advertised.
Here are a couple of photos of the stove as installed, just for the fun of it.  It really is a handsome stove.  The chimney/hearth was built in the 1970's and includes a metal 'heatilator' firebox.  Thus the vents on either side.  It actually had a wooden lintel (what could possibly go wrong?), which caught fire once long ago, thus the smoke stains to the left.  The fireplace is massive, a full 36" high and nearly 48" wide before I shrunk it by adding brick around the sides (and replaced the wooden lintel with brick!).  Still, it is 42" wide, thus the extra surround.  As a fireplace it was voracious, consuming wood by the armload every hour or two and sucking cold air in through every crack in the house.  Way better with an insert.  ;-)
View attachment 237919 View attachment 237920
