Just the tip…
Your correct, the bk meter doesnt show temps, however between the old condar and bk meter, they were basically in the same area opposed to the new condar which was pegged out. There was only three 1 1/2" x 8" pieces an oak branch in the stove, as I had just fired up the stove 20 minutes earlier. After seeing how well the Auber works, Id like to use something similar to measure the cats temp.
I use an auber for my flue temps above the shop stove. It’s been awesome for that.
First burn with the new probe, seems to be acting appropriately. It is reading higher than my oem 11 year old probe did at about the same temps. At this burn rate I’d expect the old one to be sitting around 130 position.
[Hearth.com] Just the tip…
I don’t know how I feel about the upper end accuracy of the new gauge, it was towards the end of the temp range and I didn’t feel I was running the stove that hard. I IR’ed the part of the stove right above the cat and it was a bit under 600 degrees. The beginning seems spot on which is what matters the most for catalyst engagement.
Reactions: Burnin Since 1991
Thats exactly what I was saying about my new gauge also, it appears to read high with a small fire
I’m gonna contact the co to see how they feel about it. Will flow up here when a response is received.
I tried out my new Condor last night for the first time. The gauge was pinned as far as possible showing the cat was way over 1600 degrees. I put in the old one and my older BK one. Both old gauges showed about the same temp around 1000. The fire was small so I know for fact the cat wasnt near that hot. If I knew of a digital probe to use for the cat temp, Id buy one in a second
Reaper what model condar thermometer does your boxer take?
It’s a 3-12-1, if that means something. It’s a 4” probe. I hope you have better luck getting ahold of Condar than I did this past winter. The one I just bought was from Amazon, so a return would be easier.
My new one has a gold colored dial whereas the older one has a silver dial
I had the idea of using a thermocouple, which is what the Auber is, connected to an Arduino to alert me when I have forgotten again to close the bypass and dial down the thermostat in time when starting the stove. The time between "cat hot enough" and "flue temperatures way out of line" is rather short, at least for my stove.
So an Arduino with a beeper that alerts me of excessive flue temperatures would be nice. Alas, the cable running across the stove did not get wife approval.
The standard auber kit has adjustable audible temperature alarms. The cable would be ugly, the probe length would need to be set, and I don’t know if the probe would hold up in constant 1500 degree temperatures.
The analog meters work fine for me. The worst part is that on a BK it faces the ceiling so I have to walk over to check it.
Don’t melt your flue and don’t melt your bypass retainers. Flip that bypass closed at 500 or the active line.
All right well condar got right back to me and will have the tech department individually test a meter and send it out to me as a replacement. Pretty good CS right there.
Should be interesting to see how it compares to the one in question.
Reactions: Highbeam and Todd
I noticed after a few fires the silver on mine has taken on a golden color.
This gauge is defective. Today when I went to start the stove it’s reading much lower at room temperature, as a matter of fact it went low to the point where it contacted the convection deck and spun the gauge slightly.
When new, at room temperature it would point to the F at the beginning of the range.
Reactions: Highbeam
New one has been sent out. Now awaiting the replacement.
I may not have been clear enough, but I'm using the flue temperature (~3' above the stove) to determine when to close the bypass. Exactly because of the bypass retainers.
My Condar flue thermometer goes into the "red zone" at 900F, and a bit before it reaches that I close the bypass and dial down the thermostat. Sometimes the cat thermometer doesn't indicate "hot", i.e. 500F by then, but that doesn't matter much, it catches up pretty quickly (within minutes) and then shows active.
I just started the stove for the first time this season, with a new cat. After seven years it was time for a new one. So far it's working great, not overactive, but then again I usually run low'n'slow.
New replacement installed. I feel like if this was accurate I’d be melting steel. Thoughts?
If nothing else having the coil expanding to its limits may weaken it over time. I sent mine back to Amazon for a refund. I’m wondering how you were able to get in contact with Condar so easily. Last winter I kept getting the “ the person you’re trying to get in contact with is either away from their desk or busy right now leave a message and they will contact you later”.
I emailed the lady who sent me the order confirmation and shipping info. She got back to me in less than a day. I ordered directly from them and not Amazon.
Bummer. When cold, was the needle pointing at the F? I regularly run at the top of the normal range even with well seasoned catalysts. New catalysts can be overactive and the needle will read much higher for the first few hundred hours.
This cat is on season 4. When the replacement gauge was new it was in fact pointing to the f. The stove went cold this am and it was pointing to F again so that’s ok so far. The first one I got after a few fires went way below the F when cold. Will have to see how this one plays out.
Reactions: Highbeam
Here’s how I must run my meters to prevent hitting the oem convection deck. Cold stove, several year old condar meter.
  • [Hearth.com] Just the tip…
Replacement condar at room temp. When I got it, it was pointing at the F.
That’s got to be frustrating ! Send Condar that picture and see if they’ll send you a new one.
3rd times a charm? I’m considering cutting my losses and returning these and just going with an oem.
