Hello,
We have a 5502M coming on for it's fourth year of operation.
We put it through the self-test and the exhaust fan is not working properly. It's supposed to turn on full and then reduce to a level just above the minimum pressure switch setting according to the manual.
Instead of turning on full, it tries to spin up (we have the panel off on the right-hand side as you look so I can see it moving a bit) and gets to what I guess would be about 1/10th of what it should be before spinning down and trying again. This repeats every two seconds or so until I move on to the next test.
Any idea what this could be? I took the fan off and cleaned out the ash/soot from inside the housing and the fan spins freely when pushed by hand if that makes a difference.
I'm by no means an electrical expert but I do have a multimeter so can I remove the fan and test whether the connectors are receiving the right power from the control board? Or is this likely to be something else entirely?
Thanks for reading
Thanks for reading
