I have had a CO monitor in the same room as my pellet stove (up above it - since CO is lighter than O2) and is has never gone off.
Smokey is on target.
If you have a large "sealed" hopper, CO ((FROM THE DEVICE IT IS HOOKED TO)) will gradually fill the hopper up, and leak out into the room the hopper is in. If the room is sealed, CO being a heavy gas will fill the room top to bottom, making it a death trap. Those large pellet hoppers are NOT air tight.
The reason you don't have this kind of problem with a stove, is because the stove/hopper are all contained in one unit, and fresh air is constantly being moved in and out of that room.
Please enlighten me more.... I am considering building a 4x4x12 storage bin to hold bulk pellets.... However I am making it semisealed - seems caulked with a lid - pretty much air tight to prevent the dust from when they fill it from blowing all over the shop.... Don't want to be making a mistake trying to make less work for myself.making your own bulk feed storage bin is a bad idea....unless you are an engineer.
Why would you need an internal vent with the sock if it's vented to the outside?I do have a vent pipe on my silo same size as fill pipe, that is also capped outside which is opened during delivery.
The outside vent is only open when filling to relieve pressure. You would need a vent also during normal operations, pellet level going down, left off gases on a continual basis. You could use a vent outside but you would need to ensure it is above the snow line, could look ugly (tall pipe on side of house) and might introduce moisture into the pellets.Why would you need an internal vent with the sock if it's vented to the outside?
strikes me there have been accidental deaths from people in grain silo's in the past. probably due to the same conditions
Im confused. Do pellet put out carbon monoxide with out being burned? I have just about two tons scattered all over my home. Is the CO not an issue because of the amount or because of the place I am storing? I do have a CO detector.
Let's be clear, you can only cause CO from pellets through combustion.
....in the for what it's worth dept. Here are pics of my 2 bulk fill pellets bags. Combined total of the 2 is a smigon under 3 tons. It's hard to see, but on the top of each bag are two circular vent flaps atttached to 2 dryer hose. As each bag is bulk fed from the truck, the two hoses go out my basement window, completing the venting process. The bags do "breathe" but you still have to have an escape venting route for the exhaust/dust! The bags are empty now. Vermont Renewable Fuels comes this coming Monday morning to drop off just shy of 3 tons of Green Mountain Pellets ( Softwood)Not true. There is CO produced when pellets off-gas.Carbon DIOXIDE is what is put off from composting wood and what is in farm silos. carbon monoxide is a gas that comes from incomplete combustion Of various fuels. Both deadly killers. If you have carbon monoxide in your pellet storage area it's not your pellets.
Absolutely not true! Be careful.Let's be clear, you can only cause CO from pellets through combustion.
This seems to be correct. I have a basement with a partial crawlspace that is conditioned. I have 4.5 tons of bagged pellets stacked in there and had a CO monitor with the pellets and never had any CO levels detected in the multiple times I checked it. The space did have a strong odor from the pellets though.The hoppers they are talking bout are large sealed units
for the storage of large amounts of pellets. Industrial setting.
Companies that make pellets. Large users like power plants
Not the guy that has 2-3 ton in his home
