Looking to Upgrade my insert - Osburn 2400 or Breckwell SW740I or Supreme Fusion 24
Scham
1
Hector, NY
I have an older large farm house in Upstate NY that I have updated with 1" of spray foam and batt insulation where possible. I have a hydronic baseboard heat via a propane fired boiler as my primary heat source and a Lopi model LX insert (1980s version) installed in old stone fireplace as supplemental heat source. My goal is to increase the amount of heat from burning wood to decrease my use of propane. I really like the Lopi unit that I have, but I do not think it is near as efficient as it could be. Currently I have an 8" black pipe inside my 13" terracotta chimney with no insulation and only a rain cap on the terracotta and the pipe suspended in the middle. My plan was to make some basic improvements to the Lopi install but figured it might be better to just pull the trigger on a new insert if I was going to do it right.
I am currently trying to decide between the Osburn 2400, Breckwell SW740I or the Supreme Fusion 24 but am open to suggestion. My criteria for making the decision; EPA non-catalic unit that will put our high BTUs, use less wood, provide less smoke and ash and not break the bank. Right now I am leaning toward the Supreme unit mainly because my wife likes the looks of the flush unit (might be a gimick, but I like the grill that is included). Anyone out there have any thoughts or suggestions?
jscs.moore
291
Eastern PA
I'm not familiar with the other two inserts you mentioned, but have read many posts on this site regarding the Osborn 2400 and I think most say it's a beast of a heater. I believe it has a large firebox and really cranks out the heat. I would stay away from flush mount, but that's just my opinion. You want the biggest insert you can fit in your fireplace and inserts that project out onto the hearth are going to help heat your home better during power outages. Many Osborn poster on this site who can give you more detail. Good luck with the upgrade
begreen
Mooderator
Staff member
Nov 18, 2005
99,719
South Puget Sound, WA
Agreed. The Osburn is a solid workhorse that puts out the heat.
