I'm pondering redoing my underground run this year and was wondering if anyone had experience with thermopex? Although I read all the warnings of going cheap on the underground run during initial install, I had no choice but to go homemade knowing I would replace it later.
Thermopex claims you should keep the install around 18"-24" below the surface. That keeps the piping out of the ground water you will see below the frost line. Does that sound right to the experts? My initial install I buried 3-4 ft deep but would love to just dig up 2 ft of ground this time around if the thermopex theory holds true.
I'm thinking of pushing thermopex through 6" pvc and spraying closed cell foam around the pvc. I pretty much have a straight shot 70' long so if it was in pvc I could probably pull the thermopex out and replace if I ever needed to without digging it up again. The foam around the pvc would also eliminate any condensation inside the pvc pipe. Thoughts?
When all is said and done this heating season I'll probably have burned near 10 cords. A friend of mine who used thermopex and the method above said he will use 7 and he heats a bigger house with same insulation values.
) you can use electrical pull gel. You can get it in 1/2 gal bottles up to 5gal pails. It will not hurt the PVC or any type of plastic as it's used for wire lube when pulling into conduit. A 5gal pail will make the run that much easier.
