You might want to include a pic of said small black thing.. it could be lots of things.
And if you are trying to heat the whole house with the pdvc.. while i am sure it is possible with an open floor plan and tight walls with good insulation i think you are expecting way too much.
Easiest way to get more heat is to get the stove sized to heat the space.
But with that said, some pellets do burn much hotter than others. Try other pellets.
That jumper belongs on the board somewhere.. just need to figure out where it goesFound the jumper way down on the bottom! So I don't think it's that no real difference in flame from 1-9 no real heat difference either?
Thanks I found it it wasn't missingTop right hand corner in the picture. See the little wire going across the black box things with a screw ...thats the thermostat jumper
Any idea where this might go???That jumper belongs on the board somewhere.. just need to figure out where it goes
Thank you guys for all the helpAny idea where this might go???
You guys are awesome!!I dont know if the jumpers are the same for mine.. i have a pdv not pdvc.. maybe chrisasst Could take a pic of his for you?Any idea where this might go???
Been a while since i had mine out and cant get to easily to look.. maybe the boards dont have them.idk.. dont really see anything like that on my panel.
Cool thanksThere is one of these blocks that came with the new smart stove that I bought two months ago . Talk to a tech at England stoves . He said that it was taped inside the control panel ,for use by owners . When you call england stoves for help they say they can tell you how to use it to run diagnostics on stove.
