Hi,
I know there is a very similar thread going on right now, but I feel this situation is a bit different and I didn't want to hi-jack the existing thread.
I'm in a recently renovated 1960s bungalow, re-insulated with 2x6 insulation + R7.5 foamboard on the entire exterior. To my knowledge it is knowledge reasonably well sealed.
When we moved in last year we installed a blaze king princess standalone upstairs and a PE summit in the basement. Both are hooked to new double-walled chimney systems.The reason for the different type stoves is that upstairs we run non stop, whereas in the basement the stove I only run when we spend time there or when we have guests, so say 4 to 10 times a month.
Upstairs the stove runs great, but downstairs it is extremely difficult to get draft reversed on a cold start. Thankfully once the basement stove has a good draft I've never had any issues with back-puffing, smoke infiltration or draft reversal during the coaling stage. But on startup is is quite frustrating. I've tried news paper, propane torch, opening windows, opening the door (walk-out basement), turning off the furnace, etc. It seems like the heat source I provide gets blown back in the house before ever getting into the chimney system and heating it up quickly enough to reverse the draft.
The basement chimney has two 45's in the basement and a 90 outside, followed by around 15 feet of straight run.
In my previous home, I had a Regency stove where, when I had to reverse the draft I could move the ceramic baffle out of way and shove a piece of lit news paper into the chimney. This always reversed the draft in short over. Unfortunately in the PE stove I can't just move the baffle out of the way to achieve the same effects.
Does anyone have ideas about what else I can try to reverse the downdraft??
![[Hearth.com] Nearly impossible to reverse draft - basement install [Hearth.com] Nearly impossible to reverse draft - basement install](https://www.hearth.com/talk/data/attachments/236/236335-d2700c268acbb335bf3794d1de98943d.jpg?hash=GiN4y-zMZv)
