Amazing! Part of the amazement is the 120+ degree higher temperature inside. How do vehicles start in that kind of weather... is some kind of engine block heater necessary?
Time for a humidifier
You can google anything and find the answer you want, does not mean it is a good answer.
Ask any Dr. what complications can come from low humidity. It also dries out & inflames mucus membrane lining inside your respiratory tract Which leaved you more open to illnesses, colds, flu etc. And aids in their survival.
As I said, to each their own. Enjoy
So you disagree with everything I can find?Absolutely, that is why is must be kept below 50%.When we lived in a properly cold place (currently it’s been around -30C for days, rarely passed -20C when we lived there, n.b. the preschoolers didn’t get to play outside after it passed -18C), we had city steam heating which was fabulous. Houses are built with thick walls! In the 70s new housing there went through a energy efficiency craze which was followed by a bunch of mold issues so they learned not to seal things up. So sometimes, too much humidity inside is a real problem.
Yes, when a person is walking around getting shocked by everything they touch, waking up with a sore throat every day, wood inside the structure cracking, and prolonged illnesses. If your skin is drying out and flaking . All signs that you're living in an unhealthy environment of too low humidity. Try looking at what low humidity level does to your lungs and body.View attachment 239325 So you disagree with everything I can find?
