New T-stat worked, now no augur Quadrafire 1200-I
Big help johneh, I understand prurple wires indicate SD #1, while SD #2 is connected to yellow wires.
Here's a pic of my Quadrafire 1200-I wiring for these are mounted and I am thinking that it probably doen't matter if they are the reverse location of yours or the normal mount, so long as the wires represent the correct SD.
So just know that the yellow wires on at the top though in the second image I tried to capture a number on the SD'd but this is the best I could get after several tries.
This is why I asked if each SD shows a part number so I can be sure when ordering. Because I cannot see any numbers on these two SD's. Only the lettering on the yellow wire SD "TP" if you know what that means?
By the way the blower which blows the air up the venting stainless steel chimney piping still works. Is that what you mean by convection blower?
[Hearth.com] New T-stat worked, now no augur Quadrafire 1200-I
Mountain View Hearth Products
Snap dics # 1 - 812-5060 Cost 13$
Snap Dics #2 - SRV230-0900 Cost 39$
Have you checked the manual reset Snap Dics # 3?
You said no RED LIGHT on the control board?
If so, try jumping out the stat. If there is no red light,
So, no call for heat then nothing else will work
I was not accurate. The red call light that is, for pellets when the temp reached 200°, is what I was referring to
Sorry I do not understand does the call light come on or not? Red call light has nothing to do with pellet temp. See video 1:54 to 2:10.
Reactions: johneh
No call light.
Thanks for the part #'s johneh. I'll order them right away to get before Christmas company
Yes johneh I have reset the #3 SD and it did pop so I believe it to be back to normal position
No call light.
With no call light none of the other components will have electricity. Need to figure out why no call light
ecobee light
Explain how you installed ecobee light, it needs 24v power source?
Do you have original thermostat? Did you try re installing it? Use a short piece of wire not what you have going to the ecobee.
Try jumping the thermostat. Unhook thermostat wires from stove add a jumper,(short piece of wire) from the two terminals on the stoves thermostat block.
Ecobee lite installation was done as a boiler, 2 wire only and using wall transformer for power. If I can locate the instructions I will include but today is a busy one, so as is this week. I will do my best to find the instructions so perhaps next week
