hello...looking for help on our older quadrafire. As the heading states...works fine on high or med in manual mode. If we start at medium then switch too low, stove will run fine on low until about 40 minutes as normal..... then the fan comes to a stop.....stove will sit there for hours and I believe still drops pellots...just no fan.
I read a post about blowing the vacuum line out. where is that located please?.
A pre curser to the issue as the stove was running fine until my woman forgot to clean the ash pot out while i was away hunting. stove backed up and start catching pellots on the lower bin on fire. snap disc went off and stove turned off like it should thank goodness. when i got home i cleaned out the mess best i could as she dumped water down the chute to put out the fire....so i had a mess. Not sure if that had any thing to do with the issue now we're having but i wanted to throw it out there. She also said the control box came unfastened and fell out as she was trying to fasten the side door...ugh. I knew I shouldnt of gone to the mountains
to keep the blower operating.
