Over Firing
jjensen
1
Missouri
I recently purchased a US Stove company 1261 cast iron. Its begun turning white, and some seems are bulging. Im worried about running it, but my boyfriend thinks Im paranoid...
Welcome. You have the good common sense to be concern. The stove sounds like it is being overfired. It's easy to do in this style stove. The air control is crude.
Yup, this sounds like an overfire issue. Overfiring usually is evident if the stove or stovepipe is glowing.
I recommend that you not use that stove. Structural damage can easily cause a house fire.
These stoves are usually crudely made. If it has developed air leaks then slowing it down can be hard. Hopefully there is a key damper on the flue to at least offer some control.
Reactions: Angelo C
Shoot, those stoves leave the factory with air leaks. I saw a youtube video where somebody packed all the joints on the stove with fireplace cement in an attempt to make it air tight. Seems like they said it worked. Might be a short term fix...
here it is.
The consequences are too high, I would look for a used stove that is an upgrade and trade it.
here it is.
Wow, ADD much?
