Pacific Energy cracked welds
How can the dealer (or anyone) do a draft test in the middle of the summer that means anything?
Original post:
"PE wants to do a draft test during cold weather"
Reactions: brenndatomu
I'm a big fan of my Dwyer Mark II model 25 manometer that is left hooked up 24/7...it was only $25 NOS on Ebay, and checking it is just part of my routine now when I reload...always check the draft before walking away.
Here is one for $35 shipped that I found after a 30 second search...100% rated seller too.
It says "used" (so what?) but I'm saying it's actually not, as there is no red residual in the tube from the oil, and the hose is still wrapped just like they do from the factory.
There are cheaper ones too I am sure, but you have to make sure the red gauge oil is there...it's kinda pricey to buy separately.
Like was mentioned earlier, its so easy to "thread" a bolt in the hole if you don't want to leave the gauge attached full time.
Reactions: stoveliker
That one does go a bit high in scale (so low precision in the range <0.1 where it matters).
It goes down to down to -0.010"...works for me. I run between -0.03 and -0.06 all the time.
Edit: I forgot to mention...I hook it up backwards, for more scale...so the reading will be to the right of zero...it works fine like that, I have compared it both ways, back-to-back, same reading, it just changes which side of zero it reads on.
ah, yes. That's smart
As noted earlier, I don't see signs of overfiring either. This looks like a bad weld job. The offset box reduces draft. It's possible that the draft is within spec. I'd get an inexpensive Dwyers and drill the test hole in the appliance adapter to test draft. If it is within spec, say .04-.08", then I would ask for a replacement stove. The reason being, one doesn't know what other welds are suspect.
Looking the welder across the top it looks like the welders first week on the job. Messed up and went back over it. First pic below.
They did say it would need to be done in cold weather. That being said the draft on my stove is very different depending on the weather. 37 degrees outside with fog and drizzle compared to 30 degrees clear skies and a 10 mph wind, and the stove will burn differently. Also any fire pulls air, during a draft test would they actually have a fire or would they burn 🔥 a page from a newspaper? A small amount of kindling or wait for an actual nice bed of coals? All different scenarios , each with a different amount of draft!
They'd do a proper burn, because you want the flue warm as it would be during a normal burn. It's the temperature in the flue relative to the outside temperature, that creates the draft.
