I'm really interested in doing a conversion too. My heating system right now is 2 boilers. The primary is a Harman VF3000 which burns rice coal. The backup is a System 2000 oil boiler. The boilers are hooked up in parallel (not in a series), so when the coal boiler is hot, the oil boiler remains at room temp. Only if the coil boiler malfunctions (i.e. I forget to add coal), does the oil boiler turn on. Zone valves prevent the hot water from the operating boiler fgrrom going through the other boiler.
I want to convert my Harman from coal to pellets. The coal works great and is pretty cheap (just over $200/ton delivered), but it is EXTREMELY dirty. During the coldest part of the winter I have to empty about 80 lbs of cinders out of it and fill the hopper with another 250 lbs of coal. Both processes create a tremendous amount of dirt and dust. I probably should wear a dust mask because after I do it I have a lot of coal dust in my nose.
I would really like to hear the results of the conversions. How difficult was it to put the pellet burner in, how often do you have to clean it and have you had any problems with it. The Pellx really sounds interesting with the self-clean (hook it up to an air compressor).
I tried contacting Harman to see if I could buy a pellet burner from them and got absolutely ZERO help. Just a "we don't offer a kit to do that".
Thanks!
Steve
Thanks!
Steve
![[Hearth.com] Pellet Burner Conversion [Hearth.com] Pellet Burner Conversion](https://www.hearth.com/talk/data/attachments/82/82614-97c77c809791daa546f7d35e245ba7a0.jpg?hash=qIF-5uBBQ1)
