good thing you didn't reply "No beech, i want pine." that could have been misheard/misinterpreted and started a big argument.zapny said:I brought in a whopping two splits, when I told the wife that I was going to try some pine she looked at me like I was nuts. She wants to burn some beech.
zap
Danno77 said:good thing you didn't reply "No beech, i want pine." that could have been misheard/misinterpreted and started a big argument.zapny said:I brought in a whopping two splits, when I told the wife that I was going to try some pine she looked at me like I was nuts. She wants to burn some beech.
zap
pen said:If the pine is dry it will be fine. If it hasn't by drying for a year (cut, split, stacked, 1 year) then I wouldn't even let it see the stove let alone go inside of it.
pen
pen said:If you have other options, the time certainly can't hurt it. It also isn't going to burn your house down to try a few as an experiment. But in general, pine is the exact opposite of ash. People in my area think they can get away w/ burning "green" ash. The reason they do better w/ ash when it is green than other woods is because it's living moisture content is less than that of other local woods. Pine on the other hand carries more moisture and needs to be dried longer. Once dried tho, nothing wrong w/ it at all. Most people just have a stigma about it since it isn't ready when the other wood is and therefore smolders and makes creosote since it is wet.
pen
zap
zapny said:pen said:If you have other options, the time certainly can't hurt it. It also isn't going to burn your house down to try a few as an experiment. But in general, pine is the exact opposite of ash. People in my area think they can get away w/ burning "green" ash. The reason they do better w/ ash when it is green than other woods is because it's living moisture content is less than that of other local woods. Pine on the other hand carries more moisture and needs to be dried longer. Once dried tho, nothing wrong w/ it at all. Most people just have a stigma about it since it isn't ready when the other wood is and therefore smolders and makes creosote since it is wet.
pen
I'll skip it I have plenty of other wood with cherry over one year cut and stacked and sugar maple and beech going on three years cut and stacked.
Thanks
Zap
burleymike said:Sorry you had so much trouble with pine it is all we have here and it burns great. I can start some splits with just a few sheets of news paper it is so dry. When I lived in the PNW for a couple years I noticed it was hard to get the fir to burn very well even lumber scraps were hard to start and slow to burn. All I can figure in more damp climates the pine must soak up moisture from the air.
Looks like your woodstove and your pine are ready to meet. ;-)zapny said:burleymike said:Sorry you had so much trouble with pine it is all we have here and it burns great. I can start some splits with just a few sheets of news paper it is so dry. When I lived in the PNW for a couple years I noticed it was hard to get the fir to burn very well even lumber scraps were hard to start and slow to burn. All I can figure in more damp climates the pine must soak up moisture from the air.
Decided I would test the pine with a moisture meter, attached is the picture.
zap
Carbon_Liberator said:Looks like you woodstove and your pine are ready to meet. ;-)zapny said:burleymike said:Sorry you had so much trouble with pine it is all we have here and it burns great. I can start some splits with just a few sheets of news paper it is so dry. When I lived in the PNW for a couple years I noticed it was hard to get the fir to burn very well even lumber scraps were hard to start and slow to burn. All I can figure in more damp climates the pine must soak up moisture from the air.
zap
Captain Hornet said:We have a lot of Southern White pine that is beetle killed so three years ago I bucked and split a half a cord. It was stacked outside to dry and after two years I found that it was still wet and was somewhat punky. I moved it all into the barn so it would be have a chance to dry out. So I tried some this week. I couldn't burn it if I set it on fire with gasoline. In the stove it would smoke and smolder, than go out. I suspect it was still too wet.
Captain Hornet said:With all the talk here about burning pine, I thought I might try some. We burn southern hardwood that is at least three years old so we really don't need to burn it, just thought I'd see what all the fuss is about. We have a lot of Southern White pine that is beetle killed so three years ago I bucked and split a half a cord. It was stacked outside to dry and after two years I found that it was still wet and was somewhat punky. I moved it all into the barn so it would be have a chance to dry out. So I tried some this week. I couldn't burn it if I set it on fire with gasoline. In the stove it would smoke and smolder, than go out. I suspect it was still too wet. But than I got to wondering why I was messing with pine when had real wood to burn. I pulled my dead splits from the stove and loaded them and all the rest of the pine into my wagon. I had the satisfaction of dumping all of it in the gully. Good riddance. So ends my adventures with worthless pine. David
Just started tonights fire with 4 1"x1" peices of kindling, atop 4 nice size, almost three year old pine splits. ONE regular old diamond strike on box match was all that was needed. Pines just fine!burleymike said:Sorry you had so much trouble with pine it is all we have here and it burns great. I can start some splits with just a few sheets of news paper it is so dry. When I lived in the PNW for a couple years I noticed it was hard to get the fir to burn very well even lumber scraps were hard to start and slow to burn. All I can figure in more damp climates the pine must soak up moisture from the air.
