raising the stovepipe hole in a masonry chimney
Not sure, would have to get up on top of house to measure. Attached is the inspection the chimney company did (cover page removed for friends' privacy). They don't give dimensions, except lining height =35, whatever that means. The main thing they want to do is to improve the chimney cap (which they believably say can let water in) for $1500+.
The mortar joints between the liners are shot. And thats an 8x8 so probably 6.75 or so square. I wouldnt install a stove in it.
That was my first thought. Breaking it out and drop a liner or new roof penetration. If DIYing the later is looking better. Now I get to choose the perfect location.
How can you tell ? By comparing the size of the chimney cap with the bricks ? You wouldn't install because immediate fire hazard, or just because there's likely to be a lot of creosote buildup because it's so un-smooth ? Were they full of it when they said "In good condition with no apparent issues" ?
@EbS-P: That was my first thought. Breaking it out and drop a liner or new roof penetration. If DIYing the later is looking better. Now I get to choose the perfect location.
Gonna be hard to sell either one to them. I think they're just gonna hook it up and hope for the best.
But I like the "new roof penetration" (aka. all-metal chimney) option. Maybe $2000 of parts (see attached shopping cart snapshot and assume I've missed a few minor items). Seems pretty DIY-able, the crux issues being: flash the roof penetration well (easier since it's shingles not metal), support the support-box firmly, and make sure there's no combustibles within 2" of the pipe.
  • Sad
Reactions: Whitenuckler
I can tell by the pics. Its square and by looking at the top it clearly isn't a 12x12. I would strongly recommend a liner for performance reasons. But refuse to hook a stove to it because there is no mortar between the clay tiles
I have the opinion, warn them. If it doesn't work, they were informed. Sometimes some improvement can be achieved, but at an expense.
BKVP
BKVP
The stove they have there now works (see the pix in the doc I attached in post #24 above). But as we all know, the BK is a totally different animal from some thing picked up for $80; in particular, they're going to want to be able to take advantage of its ability to do a long slow burn. More need for a good strong draft and more potential creosote buildup.
I really think a new metal chimney is the answer. I'm going to start a new thread.
Reactions: BKVP
BKVP
Yes but your just selling it. As the guy installing it i am liable if something goes wrong. So obvious safety issues I won't do it
Did a MODERATOR move this thread to DIY ? Doesn't seem like the right place; maybe I did it by mistake.
I was suggesting EVERYONE, not just the mfg.
BKVP
BKVP
Yes but as the guy doing the work I have liability issues to consider. If its just a performance issue sure i will hook it up telling them it may not work well. But im not hooking a stove to a chimney with a failed liner
Reactions: BKVP
I think that was the concern here when I asked about getting my original masonry chimney approved. The guy said he'd have to take it apart before he could say it was OK. Now I see that he was probably not able to approve the liners? That put an end to that idea. Now there is an electric fireplace covering the opening, and a new pellet stove install in the basement. I guess I could still get some sort of insert, but I don't hang around in the living room anyway.
Reactions: bholler
Raising the breech hole in a masonry chimney is not as easy as it seems but is doable.
Ensure that whatever height you choose that you still are 10" from the ceiling to ensure your cleearances are made on the double wall black pipe I suggest you utilize. Single walkl must be 18" from combustibles- so + a lower breech hole.
YOu will require to have the proper masonry cutting tools to get thru the bricka nd into the flue tile, then you will have to install a full stainless steel lienr to the 7x11 clay tile. so a 5.5 ss liner, tee and breech will do the trick.
Or hire a skillefd chimney and woodstove installer to do the job, less headaches down the road
Its for a princess they are not rated to.run on a 5.5. And the flue is not 7x11. Also the liner should be insulated (probably required by code) there is no room in that liner so the clay needs to be removed.
Reactions: BKVP
