- Aug 20, 2007
- 644
Do you guys run synthetic oil in your generators? I have thought to switching over, though I've only changed the oil 2x - just don't use the generator that much. I think it has just under 12 hours of total operation on it.
I run syn on everything. It uses so little and if it can add any protection...why not?Do you guys run synthetic oil in your generators? I have thought to switching over, though I've only changed the oil 2x - just don't use the generator that much. I think it has just under 12 hours of total operation on it.
Of course I did. And I didn't see anything refuting my statement. Even those touting other brands compare them primarily to Honda, again endorsing their position as the vanguard. The best most had said in any post predating mine was, "almost as good, for less money", when discussing any other brand.What? Did you read the thread? Have you ever owned a champion? All generators are regulated. Voltage, frequency, etc. via governors, voltage regulators, etc. Honda and Yamaha are really nice but cost double, triple, more for substantially equal or worse specs.
"Best" and "quiet" usually mean a Honda or Yamaha. Champion makes some good ones that are less expensive if a little louder is acceptable.
Many people swear by Honda's and Yamaha's and they are the industry leaders when it comes to inverter generators BUT there are many alternative companies (ie Champion, WEN, Briggs and Stratton) putting forth very competitive products at a lesser price that merit consideration when shopping around for a generator
If price isn't a concern - no brainer on a Honda or Yamaha.
If price is a concern - Champion has an inverter that size that seems to have good reports, and Home Depot sells a Lifan that size. I have the Lifan, rebranded. (King). Works great so far, although I did have to get a new battery for it.
Based on what the dirty dog guys use on the streets of NYC, it Honda 2000 model. They run all day every day. The ones I see are very ratty looking and still working. They are pricey.
I've got the Yamaha 2400i setup for propane or gas. It is a bit heavy but it's very quiet and reliable. Propane operation is for major power outages. Propane doesn't go stale so I can store a big bottle of it. Runs cleaner too.
I have a champion 3100 from Costco, I put 8-12 hours on it a week. It's comparable to the Honda 3000, I'm very happy With it quiet and good on fuel
They are clones of the Yamaha or Honda engines with many (if not all) parts being interchangeable.
Most lower priced non-inverter generators produce 60 cycle AC current directly by turning at a very specific speed. This means the engine on a non-inverter genny must run at full speed all the time- even if there is nothing connected to it. This makes more noise and burns more fuel. Some higher priced inverter generators produce DC current which is electronically inverted to 60 cycle AC power. This means the engine does not have to run at a specific speed. For this reason, when the generator is under light load the engine can run at a lower speed. This is often quieter and more fuel efficient.
I sold my camper and now need a 220v to run my house
I had a lovely Honda 3000i. Quiet, economical, reliable. Then we moved to a house with a well pump and seasonal power outages. Sold the Honda, am torn between picking up a larger inverter with 220 or going to a standby generator (I can't picture my wife rolling out a portable, hooking it up and starting it if I'm out of town...)
