stoveliker
So to pbhead. Both stoves are good stoves. The bk will be better at low and slow and will give you more even heat through the burn because of the thermostat. The regency gives you more potential btu output and a slight advantage in efficiency.
Cat warranty doesn't matter. And honestly most of our customers don't use the ashpans regardless. I know I don't either. So that generally isn't a factor between the two stoves either.
Well said. And thanks for also educating me in the process.
